Some IAPs don't broadcast in a cluster
  • 1.  Some IAPs don't broadcast in a cluster
    Posted Apr 24, 2017 12:06 PM
    Hi there,
    I have a cluster made up of two IAPs. One of them is a 325 IAP and the other one is a 305 IAP, both running version 6.5.1.0-4.3.1.2. I have tested both IAPs individually and they work properly. When I have formed a cluster, IAP 325 becomes the master and IAP 305 is a member of the cluster. IAP 325 shows up and working properly, however, IAP 305 shows up but it shows nothing respect RF, and its Radio Status LED is off. I didn't touch any advanced or RF feature and most of the features are set to default. Here you are some screenshots:
    Please help, I don't know how to solve this or the commands to use to find the root cause of this issue.
    Best regards,
    Julián
  • 2.  RE: Some IAPs don't broadcast in a cluster
    MVP EXPERT
    Posted Apr 25, 2017 03:37 AM
    Hey are you able to run #show ap bss-table  on the CLI of the IAP305?
    Can you also provide a screenshot of the IAP radio config (click on the IAP, then choose edit) and also provide the #show tech-support from the IAP305 as well?
  • 3.  RE: Some IAPs don't broadcast in a cluster
    Posted Apr 25, 2017 11:36 AM
    Hi zailon0,
    Thanks for your reply. Attached the info you need.
    Julián
    Attachment(s)
    txt
    putty.txt   164 KB 1 version
  • 4.  RE: Some IAPs don't broadcast in a cluster
    MVP EXPERT
    Posted Apr 25, 2017 11:55 AM
    I can see that the IAP is skipping initializing the radios. Are the IAP models both of the same regulatory domain e.g ROW, US or JP?
    Apr 25 15:22:13  sapd[2177]: Skipping 5Ghz initilization as no valid channel.
    Apr 25 15:22:13  sapd[2177]: Skipping 2.4Ghz initilization as no valid channel.
    Interface Name           :wifi0
    Current ARM Assignment   :0/0
    Covered channels a/g     :0/0
    Free channels a/g        :0/0
    ARM Edge State           :disable
    Last check channel/pwr   :8m:14s/8m:14s
    Last change channel/pwr  :8m:14s/8m:14s
    Next Check channel/pwr   :0s/0s
    Assignment Mode          :Single Band
    Interface Name           :wifi1
    Current ARM Assignment   :0/Max
  • 5.  RE: Some IAPs don't broadcast in a cluster
    Posted Apr 25, 2017 12:13 PM
    Hi zailon0,
    Both models are RW, and when firstly the master IAP 325 booted and I accessed the WebUI, the country code selection window appeared. I chose BR, so I supposed the AP 305 downloaded the configuration and also the code from the master AP 325, don't you?
    Julián
  • 6.  RE: Some IAPs don't broadcast in a cluster
    MVP EXPERT
    Posted Apr 25, 2017 02:10 PM
    Yep, thats exactly what it has done. You can see the Master IP is of the 325 in the tech-support. As a test are you able to statically set a a channel? Do you have another 305 you can test with just to ensure it is not a faulty AP?
  • 7.  RE: Some IAPs don't broadcast in a cluster
    Posted Apr 25, 2017 02:51 PM
    I don't have another AP 305 yet. I have tried to statically assign a channel on the AP 305 but I can't type on the channel box, it is very strange, maybe it is a faulty AP. But as I said at the beggining, if this AP runs alone as IAP, it works properly. I will do more testing and let you know.
    Julián
  • 8.  RE: Some IAPs don't broadcast in a cluster
    Posted Apr 25, 2017 05:57 PM
    Hi zailon0,
    I have upgraded both IAPs to 6.5.2.0 and now the cluster it is working properly:
    Magic?
    Julián
  • 9.  RE: Some IAPs don't broadcast in a cluster
    MVP EXPERT
    Posted Apr 26, 2017 02:52 AM
    Haha yes, the magic of a latest release ;) Glad you got it fixed!
