Sonos system not working however airgroup was enabled
  • 1.  Sonos system not working however airgroup was enabled
    Posted 30 days ago
    Hi Guys,
    I tried to set up a Sonos system on Aruba wireless network. The problem is that Sonos devices are on SSID1 (eg. vlan10), mobile devices are on SSID2 (eg. vlan20). I read about that airgroup needed for that, so I made configurations, I checked, airgroup is working (show airgroup servers list Sonos devices), however Sonos app doesn't find Sonos devices. If I put the mobile device on the same SSID/vlan where are Sonos devices, it works of course.
    Airgroup configuration:
    airgroup
     enable
     multi-swarm
     enable-guest-multicast
    airgroupservice airplay
     disable
     description AirPlay
    airgroupservice airprint
     disable
     description AirPrint
    airgroupservice Sonos
     enable
     id urn:schemas-upnp-org:service:GroupRenderingControl:1
     id urn:schemas-sonos-com:service:Queue:1
     id urn:schemas-upnp-org:service:AVTransport:1
     id urn:schemas-upnp-org:service:RenderingControl:1
     id urn:schemas-tencent-com:service:QPlay:1
     id urn:schemas-upnp-org:service:GroupManagement:1
     id urn:schemas-upnp-org:service:ZoneGroupTopology:1
     id urn:schemas-upnp-org:service:DeviceProperties:1
     id urn:schemas-upnp-org:service:MusicServices:1
     id urn:schemas-upnp-org:service:AlarmClock:1
     id urn:schemas-upnp-org:device:ZonePlayer:1
     id urn:schemas-upnp-org:service:SystemProperties:1
     id urn:schemas-upnp-org:service:ContentDirectory:1
     id urn:schemas-upnp-org:service:ConnectionManager:1
     id urn:schemas-upnp-org:service:HTControl:1
     id urn:smartspeaker-audio:service:SpeakerGroup:1
     id urn:schemas-upnp-org:service:VirtualLineIn:1
     id _sonos._tcp
     id _spotify-connect._tcp
     id _companion-link._tcp
    airgroupservice allowall
     enable
    I also set this on SSID1 and SSID2 also:
    broadcast-filter none
    multicast-rate-optimization dynamic-multicast-optimization
    xx:xx:xx:xx:xx:xx# show airgroup servers
    AirGroup Servers
    MAC                IP              Type       Host Name           Service  VLAN  Wired/Wireless  Role   Group  Name     AP-Name
    aa:aa:aa:aa:aa:aa  192.168.30.194  mDNS,DLNA  Sonos-aaaaaaaaaaaa  Sonos    10    wireless        SSID1                  xx:xx:xx:xx:xx:xx
    bb:bb:bb:bb:bb:bb  192.168.30.195  DLNA                           Sonos    10    wireless        SSID1         SonosZP  xx:xx:xx:xx:xx:xx
    Num Servers: 2.
    OS: 8.12.0.1_89864
    What can be the problem?
    The S in IOT stands for Security.
  • 2.  RE: Sonos system not working however airgroup was enabled
    Posted 30 days ago
    Have you enabled DLNA and DLNA Media Service?
  • 3.  RE: Sonos system not working however airgroup was enabled
    Posted 29 days ago
    Yes, I tried that also.
  • 4.  RE: Sonos system not working however airgroup was enabled
    Posted 16 hours ago
    Hi Safranek, Did you solve this one as I have a similar setup ie.. Sonos on a different vlan to the users.  Also have spotify connect to get running which is a complete different issue.
    From my understanding we have to also present both vlans to the APs so the multicasts can be seen.
