Sorting AP Active
  • 1.  Sorting AP Active
    Posted Jul 18, 2014 10:47 AM
    I noticed when I run the command show ap active, it sorts by IP. Is there an option to sort by AP name?
  • 2.  RE: Sorting AP Active
    Posted Jul 18, 2014 11:09 AM
    Are you trying to find the name of an AP or do you already know the name of the AP and want to see if it is up?
  • 3.  RE: Sorting AP Active
    Posted Jul 18, 2014 11:14 AM
    If you run show ap active you get the listing of all the APs that are currently active, but they are sorted by IP. I would like to sort by the AP name, so I can see if an AP is overloaded with clients or see if an AP in an area is down (which would not be listed). But having it sorted by IP makes it a little harder to see right away.
  • 4.  RE: Sorting AP Active
    Posted Jul 18, 2014 11:15 AM
    (7240) #show ap database sort-by ?
    ap-flags                Sort by AP flags
    ap-group                Sort by AP group
    ap-ip                   Sort by AP IP address
    ap-mac                  Sort by AP wired MAC address
    ap-name                 Sort by AP name
    ap-serial               Sort by AP serial number
    ap-type                 Sort by AP type
    fqln                    Sort by FQLN
    provisioned             Sort by provisioned status
    status                  Show only APs with the given status (up or down)
    switch-ip               Sort by switch IP address
    uptime                  Sort by AP uptime
    #7240
  • 5.  RE: Sorting AP Active
    Posted Jul 18, 2014 11:17 AM
    Thanks, that is what I was looking for.
