soundtouch Bose 30
  • 1.  soundtouch Bose 30
    Posted Jan 01, 2017 10:59 PM
    Hi I recently adquire a SoundTouch 30 from Bose and I download the APP for this system. The problem that I have is that sometimes I can access to the APP and sometimes I can't. I connect this SoundTouch 30 to and IAP 205H. I have already check all the options under the Service Tab and it works fine but when I killed the app and I want to access again I can't. I have to access again to the services and uncheck the allow all and check it again and then I can access again to the app. I want to make sure if there is a kill timeout or why this service is inconsistent and this app is not available all time in my network. Thanks in advance.
  • 2.  RE: soundtouch Bose 30
    Posted Jan 02, 2017 07:03 AM
    Under the SSID, under Advanced, make sure that "Broadcast Filtering" is set to "Disabled"
  • 3.  RE: soundtouch Bose 30
    Posted Jan 02, 2017 11:39 AM
    Thanks Colin for your reply. I had already changed it but still I have the same issue. Do you have on your mind another solution? Regards.
  • 4.  RE: soundtouch Bose 30
    Posted Jan 02, 2017 11:59 AM
  • 5.  RE: soundtouch Bose 30
    Posted Jan 02, 2017 08:03 PM
