Comware
Spanning Tree and loop-protection 3Com 5500-EI
  • 1.  Spanning Tree and loop-protection 3Com 5500-EI
    Posted Nov 14, 2018 11:57 AM
    I'm looking at configuring Spanning Tree on some old 3Com switches (bit of a mixed estate in terms of age, and some 3Com with some Procurve).
    On the test 3Com switch I am playing with it has loop-protection. Do I need to enable this? Is this some 3Com protocol? I'm assuming it isn't the same as Spanning Tree Loop Guard.
    #loopprotection
    #Spanningtree
    #3Com
  • 2.  RE: Spanning Tree and loop-protection 3Com 5500-EI
    Posted Nov 20, 2018 01:05 AM
    Since these are the old comware (OS) switches, please post the command here that you are playing with.
