Hi!
IMHO there is some confusion.
On your current FRX-DF-SW-00 switch (center of your Network Topology) those three BAGGs can be seen:
interface Bridge-Aggregation1
description Liens vers DF-SW-01
port link-type trunk
port trunk permit vlan 1 40 99 to 100 1350
link-aggregation mode dynamic
interface Bridge-Aggregation2
description Liens vers DF-SW-02
interface Bridge-Aggregation3
description Liens vers DF-SW-03
BAGG1 is made of GigabitEthernet 1/0/43 + GigabitEthernet 1/0/43, both physical interfaces are supposedly connected to current FRX-DF-SW-01:
interface GigabitEthernet1/0/43
port link-mode bridge
description Rocade vers FRX-DF-SW-01
port link-aggregation group 1
interface GigabitEthernet1/0/44
BAGG2 is made of GigabitEthernet 1/0/48 + Ten-GigabitEthernet 1/0/50, both physical interfaces are supposedly connected to current FRX-DF-SW-02:
interface GigabitEthernet1/0/48
description Rocade vers FRX-DF-SW-02
port link-aggregation group 2
interface Ten-GigabitEthernet1/0/50
BAGG3 is made of GigabitEthernet 1/0/47 + Ten-GigabitEthernet 1/0/49, both physical interfaces are supposedly connected to current FRX-DF-SW-03:
interface GigabitEthernet1/0/47
description Rocade vers FRX-DF-SW-03
port link-aggregation group 3
interface Ten-GigabitEthernet1/0/49
You have a clear and evident problem here.
BAGGs require that their member physical interfaces have the same media/speed/duplex so you can't simply mix a GigabitEthernet interface with a Ten-GigabitEtherenet interface on the very same BAGG as you did on link-aggregations group 2 and 3 and then expect them to work.Then...I'm just speculating here...since you haven't told us what exactly you did and what exactly you had before the current scenario...looking at current topology (switch names and configurations posted) it seems that - at some point in the past - an HPE IRF Stack (made of HPE Switches that are Comware 7 operating system driven) was present at the center of your network topology and then one of its HPE members was moved away, being re-deployed as an access switch connected to the current Core along with the others ArubaOS-Switch operating system driven switches, is this assumption correct? or - maybe - it was just moved away with no-redeployment...just leaving traces of the HPE IRF Stack configuration on the FRX-DF-SW-00 switch (like the assertion irf member 1 priority 1 ?).
Original Message:
Sent: Jul 20, 2022 05:48 AM
Subject: Spanning-tree between HPE and Aruba switches
I recently met an issue in a specific operation: actually we have 4 aruba switches connected by aggregate link between them (schema in attachment). We had an operation to replace FRX-DF-SW-00 and FRX-DF-SW-01 by HPE switches. After the replacement, a loop is detected between FRX-DF-SW-02 and FRX-DF-SW-00, FRX-DF-SW-03 and FRX-DF-SW-00 which involve the loss of connection on all of the ports of both switches FRX-DF-SW-02 and FRX-DF-SW-03 (all port became disabled). Do you have any idea of where can it come from ? If enable bpdufilter between interconnection, can it cause
Below the configuration of FRX-DF-SW-00:
<FRX-DF-SW-00>sy
<FRX-DF-SW-00>system-view
System View: return to User View with Ctrl+Z.
[FRX-DF-SW-00]dis
[FRX-DF-SW-00]display cu
[FRX-DF-SW-00]display current-configuration
version 7.1.070, Release 3506P11
sysname FRX-DF-SW-00
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
dns domain storenext.lan
dns server 10.4.1.100
dns server 10.6.1.100
lldp global enable
password-recovery enable
vlan 1
name LAN DF
vlan 40
name VLAN40
description VLAN40
vlan 99
name Wifi-Invite
vlan 100
name VOIP
vlan 105
name INTERCO-MAN
vlan 1350
name Management
stp instance 0 priority 4096
//stp instance 0 priority 32768
stp mode rstp
stp global enable
interface NULL0
interface Vlan-interface1
ip address 192.0.1.21 255.255.255.0
interface Vlan-interface1350
ip address 10.13.150.250 255.255.255.0
interface GigabitEthernet1/0/1
port trunk permit vlan 1 99 to 100
stp edged-port
poe enable
interface GigabitEthernet1/0/2
port trunk permit vlan 1 100
stp edged-port
poe enable
interface GigabitEthernet1/0/3
stp edged-port
poe enable
stp edged-port
poe enable
interface GigabitEthernet1/0/5
stp edged-port
poe enable
interface GigabitEthernet1/0/6
description FRX-DF-FW-01 LAN
port trunk permit vlan 1 99 to 100 1350
stp edged-port
poe enable
interface GigabitEthernet1/0/7
stp edged-port
poe enable
interface GigabitEthernet1/0/8
port trunk pvid vlan 99
stp edged-port
poe enable
interface GigabitEthernet1/0/9
stp edged-port
poe enable
interface GigabitEthernet1/0/10
stp edged-port
poe enable
interface GigabitEthernet1/0/11
stp edged-port
poe enable
interface GigabitEthernet1/0/12
stp edged-port
poe enable
interface GigabitEthernet1/0/13
stp edged-port
poe enable
interface GigabitEthernet1/0/14
stp edged-port
poe enable
interface GigabitEthernet1/0/15
stp edged-port
poe enable
interface GigabitEthernet1/0/16
stp edged-port
poe enable
interface GigabitEthernet1/0/17
port trunk permit vlan 1 40 100
stp edged-port
poe enable
interface GigabitEthernet1/0/18
stp edged-port
poe enable
interface GigabitEthernet1/0/19
stp edged-port
poe enable
interface GigabitEthernet1/0/20
stp edged-port
poe enable
interface GigabitEthernet1/0/21
stp edged-port
poe enable
interface GigabitEthernet1/0/22
stp edged-port
poe enable
interface GigabitEthernet1/0/23
description ILO_HP
stp edged-port
poe enable
interface GigabitEthernet1/0/24
stp edged-port
poe enable
interface GigabitEthernet1/0/25
stp edged-port
poe enable
interface GigabitEthernet1/0/26
stp edged-port
poe enable
interface GigabitEthernet1/0/27
stp edged-port
poe enable
interface GigabitEthernet1/0/28
stp edged-port
poe enable
interface GigabitEthernet1/0/29
stp edged-port
poe enable
interface GigabitEthernet1/0/30
stp edged-port
poe enable
interface GigabitEthernet1/0/31
description Wifi - AP02
stp edged-port
poe enable
interface GigabitEthernet1/0/32
stp edged-port
poe enable
interface GigabitEthernet1/0/33
stp edged-port
poe enable
interface GigabitEthernet1/0/34
description Wifi - AP03
stp edged-port
poe enable
interface GigabitEthernet1/0/35
description Wifi - AP09
stp edged-port
poe enable
interface GigabitEthernet1/0/36
stp edged-port
poe enable
interface GigabitEthernet1/0/37
description Wifi - AP04
stp edged-port
poe enable
interface GigabitEthernet1/0/38
description INTERCO PORT10-FGT1
port access vlan 105
stp edged-port
poe enable
interface GigabitEthernet1/0/39
description ESX_HP
poe enable
interface GigabitEthernet1/0/40
description INTERCO PORT10-FGT2
stp edged-port
poe enable
interface GigabitEthernet1/0/41
description INTERCO RTR-MAN
stp edged-port
poe enable
interface GigabitEthernet1/0/42
stp edged-port
poe enable
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface M-GigabitEthernet0/0/0
interface Ten-GigabitEthernet1/0/51
interface Ten-GigabitEthernet1/0/52
scheduler logfile size 16
line class aux
user-role network-admin
line class vty
user-role network-operator
line aux 0
line vty 0 15
authentication-mode scheme
protocol inbound ssh
line vty 16 63
ip route-static 0.0.0.0 0 10.13.150.254
ip route-static 0.0.0.0 0 192.0.1.254
snmp-agent
snmp-agent local-engineid 800063A280DC680CDC612C00000001
snmp-agent community read smcpro16
snmp-agent sys-info version v1 v3
snmp-agent target-host trap address udp-domain 10.4.5.14 params securityname smcpro16
snmp-agent trap enable arp
snmp-agent trap enable radius
snmp-agent trap enable stp
ssh server enable
sntp unicast-server ntp.storenext.lan
radius scheme system
user-name-format without-domain
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user adm_sw_smcp class manage
password hash $h$6$rA6q8GPHu152oYij$XLWlV2zHTd+EHCEtBRS39X1+db/PL+MxbnEnD63l3BCY3JhZXopbJuN5Qi7/B699O2TpHgApcE+ni+Yc5muL5w==
service-type http https ssh
authorization-attribute user-role network-admin
authorization-attribute user-role network-operator
ip https enable
return
[FRX-DF-SW-00]
Below the configuration of FRX-DF-SW-02:
DF-SW-05# sh running-config
Running configuration:
; J9772A Configuration Editor; Created on release #YA.16.02.0008
; Ver #0d:10.82.34.47.18.28.f3.84.9c.63.ff.37.27:bb
hostname "DF-SW-05"
dhcp-snooping
trunk 48,50 trk1 trunk
sntp unicast
sntp server priority 1 192.0.1.12
interface 21
name "Wifi - AP01"
exit
interface 22
name "Wifi - AP05"
exit
interface 48
name "Rocade Cuivre Baie Serveur"
exit
interface 50
name "Rocade Fibre Baie Serveur"
exit
snmp-server community "public" unrestricted
snmp-server host 192.0.1.14 community "public"
snmp-server host 169.254.50.157 community "public"
snmp-server host 192.0.1.51 community "public"
snmp-server location "Baie 1ier Etage"
vlan 1
name "DEFAULT_VLAN"
untagged 1-47,49,51-52,Trk1
ip address 192.0.1.25 255.255.255.0
exit
vlan 99
name "Wifi-Invite"
tagged 21-22,Trk1
no ip address
exit
vlan 100
name "VOIP"
tagged 1-42,51-52,Trk1
no ip address
exit
spanning-tree
spanning-tree Trk1 priority 4
no tftp server
no dhcp config-file-update
no dhcp image-file-update
no dhcp tr69-acs-url
password manager
DF-SW-05# sh int brief
Status and Counters - Port Status
| Intrusion MDI Flow
Port Type | Alert Enabled Status Mode Mode Ctrl
1 100/1000T | No Yes Down 1000FDx MDIX off
2 100/1000T | No Yes Down 1000FDx MDI off
3 100/1000T | No Yes Down 1000FDx MDIX off
4 100/1000T | No Yes Down 1000FDx MDI off
5 100/1000T | No Yes Up 1000FDx MDI off
6 100/1000T | No Yes Down 1000FDx MDI off
7 100/1000T | No Yes Down 1000FDx MDIX off
8 100/1000T | No Yes Down 1000FDx MDI off
9 100/1000T | No Yes Down 1000FDx MDIX off
10 100/1000T | No Yes Down 1000FDx MDIX off
11 100/1000T | No Yes Down 1000FDx MDIX off
12 100/1000T | No Yes Down 1000FDx MDI off
13 100/1000T | No Yes Down 1000FDx MDIX off
14 100/1000T | No Yes Down 1000FDx MDIX off
15 100/1000T | No Yes Down 1000FDx MDIX off
16 100/1000T | No Yes Down 1000FDx MDIX off
17 100/1000T | No Yes Down 1000FDx MDI off
18 100/1000T | No Yes Down 1000FDx MDIX off
19 100/1000T | No Yes Down 1000FDx MDI off
20 100/1000T | No Yes Down 1000FDx MDI off
21 100/1000T | No Yes Up 1000FDx MDI off
22 100/1000T | No Yes Up 1000FDx MDI off
23 100/1000T | No Yes Up 1000FDx MDIX off
24 100/1000T | No Yes Down 1000FDx MDIX off
25 100/1000T | No Yes Down 1000FDx MDIX off
26 100/1000T | No Yes Down 1000FDx MDI off
27 100/1000T | No Yes Down 1000FDx MDI off
28 100/1000T | No Yes Down 1000FDx MDIX off
29 100/1000T | No Yes Down 1000FDx MDIX off
30 100/1000T | No Yes Up 1000FDx MDI off
31 100/1000T | No Yes Down 1000FDx MDI off
32 100/1000T | No Yes Up 1000FDx MDIX off
33 100/1000T | No Yes Up 1000FDx MDI off
34 100/1000T | No Yes Down 1000FDx MDIX off
35 100/1000T | No Yes Down 1000FDx MDI off
36 100/1000T | No Yes Down 1000FDx MDI off
37 100/1000T | No Yes Down 1000FDx MDI off
38 100/1000T | No Yes Up 1000FDx MDIX off
39 100/1000T | No Yes Down 1000FDx MDI off
40 100/1000T | No Yes Down 1000FDx MDI off
41 100/1000T | No Yes Down 1000FDx MDIX off
42 100/1000T | No Yes Down 1000FDx MDI off
43 100/1000T | No Yes Down 1000FDx MDIX off
44 100/1000T | No Yes Down 1000FDx MDI off
45 100/1000T | No Yes Down 1000FDx MDI off
46 100/1000T | No Yes Down 1000FDx MDI off
47 100/1000T | No Yes Down 1000FDx MDI off
48-Trk1 100/1000T | No Yes Up 1000FDx MDI off
49 | No Yes Down . off
50-Trk1 1000SX | No Yes Up 1000FDx NA off
51 | No Yes Down . off
52 | No Yes Down . off
DF-SW-05# sh vlan
Status and Counters - VLAN Information
Maximum VLANs to support : 256
Primary VLAN : DEFAULT_VLAN
Management VLAN :
VLAN ID Name | Status Voice Jumbo
1 DEFAULT_VLAN | Port-based No No
99 Wifi-Invite | Port-based No No
100 VOIP | Port-based No No
DF-SW-05# sh run int ethernet 1
interface 1
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 2
interface 2
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 3
interface 3
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 4
interface 4
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 5
interface 5
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 6
interface 6
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 7
interface 7
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 8
interface 8
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 9
interface 9
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 10
interface 10
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 11
interface 11
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 12
interface 12
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 13
interface 13
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 14
interface 14
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 15
interface 15
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 16
interface 16
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 17
interface 17
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 18
interface 18
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 19
interface 19
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 20
interface 20
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 21
interface 21
name "Wifi - AP01"
tagged vlan 99-100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 22
interface 22
name "Wifi - AP05"
tagged vlan 99-100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 23
interface 23
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 24
interface 24
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 25
interface 25
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 26
interface 26
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 27
interface 27
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 28
interface 28
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 29
interface 29
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 30
interface 30
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 31
interface 31
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 32
interface 32
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 33
interface 33
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 34
interface 34
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 35
interface 35
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 36
interface 36
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 37
interface 37
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 38
interface 38
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 39
interface 39
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 40
interface 40
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 41
interface 41
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 42
interface 42
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 43
interface 43
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 44
interface 44
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 45
interface 45
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 46
interface 46
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 47
interface 47
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 48
interface 48
untagged vlan 1
trunk trk1 trunk
exit
DF-SW-05# sh run int ethernet 49
interface 49
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 50
interface 50
untagged vlan 1
trunk trk1 trunk
exit
DF-SW-05# sh run int ethernet 51
interface 51
tagged vlan 100
untagged vlan 1
exit
DF-SW-05# sh run int ethernet 52
interface 52
tagged vlan 100
untagged vlan 1
exit
DF-SW-05#
Below the configuration of DF-SW-03
DF-SW-04# sh running-config
hostname "DF-SW-04"
dhcp-snooping
trunk 47,49 trk1 trunk
timesync ntp
sntp unicast
ntp unicast
ntp server 192.0.1.12 iburst
ntp enable
time daylight-time-rule western-europe
time timezone 60
ip default-gateway 192.0.1.254
interface 38
name "Wifi - AP08"
exit
interface 39
name "Wifi - AP07"
exit
interface 40
name "Wifi - AP06"
exit
interface 41
name "Wifi - AP11"
exit
interface 42
name "Wifi - AP10"
exit
interface 43
name "VTL_SYNO"
exit
interface 44
name "VTL_SYNO"
exit
interface 47
exit
interface 49
exit
snmp-server location "Baie 3e Etage"
vlan 1
name "DEFAULT_VLAN"
no untagged 43-44
untagged 1-42,45-46,48,50-52,Trk1
ip address 192.0.1.24 255.255.255.0
exit
vlan 40
name "VLAN40"
untagged 43-44
tagged Trk1
no ip address
exit
vlan 99
name "Wifi-Invite"
tagged 1,38-42,Trk1
no ip address
exit
vlan 100
name "VOIP"
tagged 1-46,48,50-52,Trk1
no ip address
exit
spanning-tree
no tftp server
password manager
DF-SW-04# sh vlan
Management VLAN :
40 VLAN40 | Port-based No No
DF-SW-04# sh run int ethernet 1
interface 1
tagged vlan 99-100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 2
interface 2
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 3
interface 3
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 4
interface 4
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 5
interface 5
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 6
interface 6
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 7
interface 7
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 8
interface 8
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 9
interface 9
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 10
interface 10
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 11
interface 11
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 12
interface 12
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 13
interface 13
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 14
interface 14
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 15
interface 15
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 16
interface 16
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 17
interface 17
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 18
interface 18
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 19
interface 19
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 20
interface 20
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 21
interface 21
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 22
interface 22
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 23
interface 23
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 24
interface 24
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 25
interface 25
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 26
interface 26
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 27
interface 27
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 28
interface 28
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 29
interface 29
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 30
interface 30
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 31
interface 31
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 32
interface 32
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 33
interface 33
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 34
interface 34
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 35
interface 35
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 36
interface 36
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 37
interface 37
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 38
interface 38
name "Wifi - AP08"
tagged vlan 99-100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 39
interface 39
name "Wifi - AP07"
tagged vlan 99-100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 40
interface 40
name "Wifi - AP06"
tagged vlan 99-100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 41
interface 41
name "Wifi - AP11"
tagged vlan 99-100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 42
interface 42
name "Wifi - AP10"
tagged vlan 99-100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 43
interface 43
name "VTL_SYNO"
tagged vlan 100
untagged vlan 40
exit
DF-SW-04# sh run int ethernet 44
interface 44
name "VTL_SYNO"
tagged vlan 100
untagged vlan 40
exit
DF-SW-04# sh run int ethernet 45
interface 45
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 46
interface 46
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 47
interface 47
untagged vlan 1
trunk trk1 trunk
exit
DF-SW-04# sh run int ethernet 48
interface 48
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 49
interface 49
untagged vlan 1
trunk trk1 trunk
exit
DF-SW-04# sh run int ethernet 50
interface 50
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 51
interface 51
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh run int ethernet 52
interface 52
tagged vlan 100
untagged vlan 1
exit
DF-SW-04# sh interfaces brief
| Intrusion MDI Flow
3 100/1000T | No Yes Down 1000FDx MDI off
6 100/1000T | No Yes Up 1000FDx MDI off
7 100/1000T | No Yes Up 1000FDx MDI off
9 100/1000T | No Yes Up 1000FDx MDIX off
11 100/1000T | No Yes Up 1000FDx MDIX off
12 100/1000T | No Yes Up 1000FDx MDIX off
15 100/1000T | No Yes Up 1000FDx MDI off
16 100/1000T | No Yes Down 1000FDx MDI off
18 100/1000T | No Yes Down 1000FDx MDI off
20 100/1000T | No Yes Down 1000FDx MDIX off
21 100/1000T | No Yes Down 1000FDx MDI off
22 100/1000T | No Yes Up 1000FDx MDIX off
23 100/1000T | No Yes Down 1000FDx MDI off
24 100/1000T | No Yes Down 1000FDx MDI off
26 100/1000T | No Yes Down 1000FDx MDIX off
27 100/1000T | No Yes Down 1000FDx MDIX off
28 100/1000T | No Yes Up 1000FDx MDI off
30 100/1000T | No Yes Up 100FDx MDIX off
31 100/1000T | No Yes Down 1000FDx MDIX off
32 100/1000T | No Yes Down 1000FDx MDIX off
33 100/1000T | No Yes Down 1000FDx MDI off
35 100/1000T | No Yes Up 1000FDx MDIX off
37 100/1000T | No Yes Down 1000FDx MDIX off
39 100/1000T | No Yes Up 1000FDx MDIX off
40 100/1000T | No Yes Up 1000FDx MDI off
41 100/1000T | No Yes Up 1000FDx MDI off
42 100/1000T | No Yes Up 1000FDx MDIX off
43 100/1000T | No Yes Up 1000FDx MDIX off
44 100/1000T | No Yes Up 1000FDx MDI off
45 100/1000T | No Yes Up 1000FDx MDIX off
46 100/1000T | No Yes Up 1000FDx MDI off
47-Trk1 100/1000T | No Yes Up 1000FDx MDIX off
48 100/1000T | No Yes Down 1000FDx MDIX off
49-Trk1 1000SX | No Yes Up 1000FDx NA off
50 | No Yes Down . off
DF-SW-04#
