Wired Intelligent Edge
Spanning Tree blocks a switch uplink
  • 1.  Spanning Tree blocks a switch uplink
    Posted Dec 28, 2012 06:54 AM
    Hi folks
    I have a n HP2810-48G as "core switch", this switch has the following STP setup
    Multiple Spanning Tree (MST) Information
    STP Enabled : Yes
    Force Version : RSTP-operation
    IST Mapped VLANs : 1-4094
    Switch MAC Address : 0021f7-9d6400
    Switch Priority : 4096
    Max Age : 20
    Max Hops : 20
    Forward Delay : 15
    Topology Change Count : 2147
    Time Since Last Change : 12 mins
    CST Root MAC Address : 0021f7-9d6400
    CST Root Priority : 4096
    CST Root Path Cost : 0
    CST Root Port : This switch is root
    IST Regional Root MAC Address : 0021f7-9d6400
    IST Regional Root Priority : 4096
    IST Regional Root Path Cost : 0
    IST Remaining Hops : 20
    Root Guard Ports :
    TCN Guard Ports :
    Protected Ports :
    Filtered Ports :
    To this switch I have several other HP switches connected, all seems to be working fine. Now I'm trying to connect a new switch to the 2810 and the port on the 2810 is blocked by STP almost directly. I've also tried with a Cisco switch in the same port with same result.
    How can this be? A out of the box new switch, all I've done on it is to set up the management VLAN and IP address.
    Regards
    /Fredrik
    #Spanningtree
    #VLAN
    #2810-48g
  • 2.  RE: Spanning Tree blocks a switch uplink
    Posted Dec 28, 2012 07:29 AM
    Hi
    STP should not block a port unless you have a loop in the network. Are you certain it's STP that's blocking the traffic?
    You say you set up management VLAN. Do you mean the HP Secure Management VLAN? Please note that if you configure a Secure Mgmt VLAN, only clients in that VLAN are able to manage the switch. No traffic will be routed in or out of Secure Mgmt VLAN.
  • 3.  RE: Spanning Tree blocks a switch uplink
    Posted Dec 28, 2012 07:43 AM
    I get this in the log a every minute when the switch is connected.
    I 12/28/12 15:09:29 ports: port 16 is now off-line
    I 12/28/12 15:10:38 ports: port 16 is Blocked by STP
    I 12/28/12 15:10:41 ports: port 16 is now on-line
    By management I mean I assign an IP address to a VLAN like below. The same is done on our other HP switches.
    vlan xyz
    name "switchnet"
    ip address x.x.x.x
    Is there something I can do to trouble shoot this further. I'm more of a Cisco guy but HP leaves me at a loss
  • 4.  RE: Spanning Tree blocks a switch uplink
    Posted Dec 28, 2012 08:34 AM
    Hi
    What happens here is:
    - The port goes offline for unknown reason
    - The port comes online
    - STP blocks it for three second
    - STP releases the port and it shows as online.
    This is expected behavior. When a port comes online STP will always kick in. So STP is not the root cause of your problem. Neither is your management VLAN. The question is why is the link flapping in the first place. If you disable STP on the switches you will see exactly same behavior, minus the STP message.
    What the root cause is can't be determined with this information. My suggestion:
    - Ensure both switches are running current software
    - Connect the switches
    - If you have still problems, gather show tech all -command output (or similar) from both switches
    - Call support
  • 5.  RE: Spanning Tree blocks a switch uplink
    Posted Dec 28, 2012 05:28 PM
    Hi Fredrik,
    As Arimo mentioned, you're seeing normal behaviour in those log messages.  The real test is whether the link remains blocked by spanning tree (which those log messages don't really indicate).  Post the complete output of 'show run', 'show spanning-tree', and 'show spanning-tree bpdu-protection' from both this switch and new the switch you plugged in and we'll be able to get a better picture.  Also grab all log messages from, say, 1-2 minutes before & after you plug it in.
  • 6.  RE: Spanning Tree blocks a switch uplink
    Posted Jan 03, 2013 05:26 AM
    Look, I understand you need as much as possible to help me out but I'm reluctant to post the show run from a production core switch. Below is however the log on the core switch a few minutes after I've connected the switch, doesn't matter if it's a Cisco switch or an HP. Also I've included show spanning-tree and bpdu-protection
    I 12/28/12 15:56:00 ports: port 16 is now off-line
    I 12/28/12 15:56:03 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:04 ports: port 16 is now off-line
    I 12/28/12 15:56:07 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:08 ports: port 16 is now off-line
    I 12/28/12 15:56:11 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:12 ports: port 16 is now off-line
    I 12/28/12 15:56:18 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:19 ports: port 16 is now off-line
    I 12/28/12 15:56:22 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:24 ports: port 16 is now off-line
    I 12/28/12 15:56:27 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:27 ports: port 16 is now off-line
    I 12/28/12 15:56:30 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:31 ports: port 16 is now off-line
    I 12/28/12 15:56:34 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:35 ports: port 16 is now off-line
    I 12/28/12 15:56:37 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:38 ports: port 16 is now off-line
    I 12/28/12 15:56:45 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:45 ports: port 16 is now off-line
    I 12/28/12 15:56:48 ports: port 16 is Blocked by STP
    I 12/28/12 15:56:49 ports: port 16 is now off-line
    I 12/28/12 15:57:00 ports: port 16 is Blocked by STP
    I 12/28/12 15:57:01 ports: port 16 is now off-line
    I 12/28/12 15:57:04 ports: port 16 is Blocked by STP
    I 12/28/12 15:57:05 ports: port 16 is now off-line
    I 12/28/12 15:57:11 ports: port 16 is Blocked by STP
    I 12/28/12 15:57:12 ports: port 16 is now off-line
    I 12/28/12 15:57:15 ports: port 16 is Blocked by STP
    I 12/28/12 15:57:16 ports: port 16 is now off-line
    I 12/28/12 15:57:19 ports: port 16 is Blocked by STP
    I 12/28/12 15:57:20 ports: port 16 is now off-line
    STP Enabled : Yes
    Max Age : 20
    Max Hops : 20
    Forward Delay : 15
    Topology Change Count : 2209
    Time Since Last Change : 5 days
    Root Guard Ports :
    TCN Guard Ports :
    Protected Ports :
    Filtered Ports :
    | Prio | Designated Hello
    Port Type | Cost rity State | Bridge Time PtP Edge
    1 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    2 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    3 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    4 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    5 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    6 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    7 100/1000T | 200000 128 Forwarding | 0021f7-9d6400 2 Yes No
    8 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    9 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    10 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    11 100/1000T | 2000000 128 Forwarding | 0021f7-9d6400 2 Yes No
    12 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    13 100/1000T | 200000 128 Forwarding | 0021f7-9d6400 2 Yes No
    14 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    15 100/1000T | 200000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    16 100/1000T | 200000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    17 100/1000T | 200000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    18 100/1000T | 200000 128 Forwarding | 0021f7-9d6400 2 Yes No
    19 100/1000T | 200000 128 Forwarding | 0021f7-9d6400 2 Yes No
    20 100/1000T | Auto 128 Disabled |
    21 100/1000T | Auto 128 Disabled |
    22 100/1000T | Auto 128 Disabled |
    23 100/1000T | Auto 128 Disabled |
    24 100/1000T | Auto 128 Disabled |
    25 100/1000T | Auto 128 Disabled |
    26 100/1000T | Auto 128 Disabled |
    27 100/1000T | Auto 128 Disabled |
    28 100/1000T | Auto 128 Disabled |
    29 100/1000T | Auto 128 Disabled |
    30 100/1000T | Auto 128 Disabled |
    31 100/1000T | Auto 128 Disabled |
    32 100/1000T | Auto 128 Disabled |
    33 100/1000T | Auto 128 Disabled |
    34 100/1000T | Auto 128 Disabled |
    35 100/1000T | Auto 128 Disabled |
    36 100/1000T | Auto 128 Disabled |
    37 100/1000T | Auto 128 Disabled |
    38 100/1000T | 200000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    39 100/1000T | 200000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    40 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    41 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    42 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    43 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes Yes
    44 100/1000T | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    45 1000LX | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    46 100/1000T | Auto 128 Disabled |
    47 1000LX | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    48 1000LX | 20000 128 Forwarding | 0021f7-9d6400 2 Yes No
    Status and Counters - STP Port(s) BPDU Protection Information
    BPDU Protection Timeout (sec) : 0
    Protected Ports :
  • 7.  RE: Spanning Tree blocks a switch uplink
    Posted Jan 04, 2013 02:17 AM
    Hi TheH0ff,
    I understand your reluctance to post configs, but it really does make it a lot easier to help you.  If you want to anonymise the IP addresses and VLAN numbers that should make it reasonably safe to post.
    The diagnostic information that you've provided shows that it is not spanning tree blocking the port.  It is in forwarding state as expected, and no BPDU protection is happening.  The reason for the log message saying that it is blocking it is because the port is going down.  It is quite strange that we're not seeing log messages stating that the port is online.  Normally, i would expect to see something like this:
    Aug 27 21:07:33 192.168.1.4 ports:  port 13 is Blocked by LACP
    Aug 27 21:07:34 192.168.1.4 ports:  port 13 is now off-line
    Aug 27 21:07:38 192.168.1.4 ports:  port 13 is Blocked by LACP
    Aug 27 21:07:38 192.168.1.4 ports:  port 13 is Blocked by STP
    Aug 27 21:07:40 192.168.1.4 ports:  port 13 is now on-line
    Aug 27 21:07:51 192.168.1.4 ports:  port 13 is now off-line
    Aug 27 21:07:56 192.168.1.4 ports:  port 13 is Blocked by LACP
    Aug 27 21:07:59 192.168.1.4 ports:  port 13 is Blocked by STP
    Aug 27 21:08:01 192.168.1.4 ports:  port 13 is now on-line
    The fact that you're not seeing an on-line message suggests to me that there are some issues with cabling.  What does 'show interfaces 16' report - any errors?
  • 8.  RE: Spanning Tree blocks a switch uplink
    Posted Jan 04, 2013 06:49 AM
    Here's a show interface for the port, looks good I'd say.
    Link Status : Up
    Totals (Since boot or last clear) :
    Bytes Rx : 2,292,148,536 Bytes Tx : 3,825,949,595
    Unicast Rx : 22,107,770 Unicast Tx : 33,834,939
    Bcast/Mcast Rx : 261,365 Bcast/Mcast Tx : 102,984,687
    Errors (Since boot or last clear) :
    FCS Rx : 45 Drops Rx : 0
    Alignment Rx : 0 Collisions Tx : 0
    Runts Rx : 0 Late Colln Tx : 0
    Giants Rx : 0 Excessive Colln : 0
    Total Rx Errors : 62 Deferred Tx : 0
    Rates (5 minute weighted average) :
    Total Rx (bps) : 411600 Total Tx (bps) : 716056
    Unicast Rx (Pkts/sec) : 1 Unicast Tx (Pkts/sec) : 4
    B/Mcast Rx (Pkts/sec) : 0 B/Mcast Tx (Pkts/sec) : 54
    Utilization Rx : 00.41 % Utilization Tx : 00.71 %
    However you mentioning the cabling got me thinking. I'm connecting the switch over the house wiring, I disconnect my PC and plug the cable into the switch. Could it be that I need a cross over cable?
    #crossovercable
  • 9.  RE: Spanning Tree blocks a switch uplink
    Posted Jan 04, 2013 01:59 PM
    I would be tempted to set the port down to auto-100, and see if it's stable if you suspect a cabling problem. Is ir running at Gigabit speeds on the PC connection?
  • 10.  RE: Spanning Tree blocks a switch uplink
    Posted Jan 04, 2013 02:55 PM
    2810s do not need crossover cables; they have auto-MDI on all ports. (Use 'show interfaces brief' to check the MDI status of each port.)
    Try connecting another switch using the same cable as you used to connect your PC - i think it will yield different results. As Richard suggested, hard-coding the speed might help. I've used this before when i knew that wire 7 in the building cabling was broken but 1, 2, 3, and 6 were fine.
