Specify Outer GRE-tunnel DSCP priority
  • 1.  Specify Outer GRE-tunnel DSCP priority
    Posted Sep 16, 2013 08:47 AM
    Hi.
    Is it possible in any way to specify the DSCP value for the GRE packets going from the AP to the Controller?
    In this case I do not need to set the DSCP value for the traffic inside the tunnel, but the DSCP for the tunnel itself.
  • 2.  RE: Specify Outer GRE-tunnel DSCP priority
    Posted Sep 16, 2013 09:47 AM
    Under the AP-System Profile
  • 3.  RE: Specify Outer GRE-tunnel DSCP priority
    Posted Sep 16, 2013 01:53 PM
    That parameter ONLY sets the DSCP for heartbeats between the access point and the controller, not the data in the GRE tunnel.
  • 4.  RE: Specify Outer GRE-tunnel DSCP priority
    Posted Sep 17, 2013 02:46 AM
    Thank you victorfabian, but that setting does not solve my issue.
    As cjoseph points out, that setting does nothing with the GRE data, only the GRE heartbeats.
  • 5.  RE: Specify Outer GRE-tunnel DSCP priority
    Posted Aug 06, 2015 01:02 AM
    The AP should take the DSCP value in the packet from the client and slap that on the GRE packets.
