Spectrum analysis commands
  • 1.  Spectrum analysis commands
    Posted Jun 01, 2015 09:23 AM
    Some of the spectrum analysis commands run on a remote AP save the file with the output -
    Printing 60 lines to file(s) in /tmp/spectrum directory on the AP
    How can I access these files?
    I'm running this command on a controller running 6.1.3.5 code.
  • 2.  RE: Spectrum analysis commands
    Posted Jun 01, 2015 10:35 AM
    If you configure a tftp dump server this information will transfer to that server after your run the command.
    http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-retrieve-a-core-dump-from-an-AP-in-the-event-of-a/ta-p/180550
  • 3.  RE: Spectrum analysis commands
    Posted Jun 02, 2015 04:03 AM
    I have configured the dump server but no files arrive at the server when I run the commands. I know the server is reachable because it responds to pings and I can transfer a file from the controller manually using the copy command.
  • 4.  RE: Spectrum analysis commands
    Posted Jun 02, 2015 04:05 AM
    Sorry, it seems that only some of the commands have produced an output as I've run a couple more, one of which has resulted in a file being transferred successfully.
