Hello!
Are there recommendations on wich controller a spectrum analyzer should terminate?If on site a master local deployment is present, does it make a difference if the SA terminates on master or local?
Thank you!
No, but it should be a controller that has sufficient RFprotect licenses, because spectrum does not work without that.
