Spectrum analyzer location tracking
  • 1.  Spectrum analyzer location tracking
    Posted Dec 19, 2014 04:24 AM
    Hi All,
    If I use Spectrum Analyzer and I see a bluetooth device on a certain channel, can I use location tracking in AirWave to localize the device?
    Can I use Spectrum Monitor to see IDS events? Is it using the same IDS/IPS monitoring functionality like AirMonitor (for example to see DOS, RogueAP, Containment, ...)?
  • 2.  RE: Spectrum analyzer location tracking
    Posted Dec 19, 2014 06:39 AM
    - You can enable the "interferers" checkbox under devices to "see" bluetooth devices.  According to online help- "Interferer indicators works for ArubaOS devices running 6.1 or newer that have run the mgmt-server type AMPcommand, and have APs performing Spectrum analysis through hybrid scanning or dedicated spectrum monitors."  In practice, interferers can be difficult to locate accurately.
    - You cannot visualize IDS/IPS events in VisualRF, but it can locate Rogues, yes..
