Spectrum monitor
  • 1.  Spectrum monitor
    Posted May 26, 2014 04:52 AM
    Hi there,
    I would like to turn the spectrum analyzer on the 650 controller, but once created the new ap-group (spectrum mon.) and added 1 ap 5 of these, when I apply the change, all become ap spectrum monitor : why?
    Thanx in advance.
  • 2.  RE: Spectrum monitor
    Posted May 26, 2014 05:17 AM
    create a new profiles...not just new ap-group.
    if your two ap-groups using the same profiles it will effect all your ap's
  • 3.  RE: Spectrum monitor
    Posted May 26, 2014 01:41 PM
    Another method you can use if you just want to move one AP at a time into Spectrum mode is to use "Spectrum Override"
    Go into Configuration-> Advanced Services->All Profiles->Spectrum Override.  Enter the name of the AP you wish to turn into a dedicated Spectrum Analyzer, select the band, and click apply.  To put the AP back into service go back to the same screen and delete the AP.
  • 4.  RE: Spectrum monitor
    Posted May 26, 2014 09:58 PM
    You must have changed the profile that the other AP group uses like mentioned above.
    How to make a Aruba Spectrum Monitor
