It is possible to create a spectrum monitor in 2.4ghz and make 5ghz on access mode?
I mean
2.4ghz-->spectrum monitor
5ghz-->access
The idea is having an instant in which i can connect through the 5ghz band and scan for noises in 2.4ghz without connecting it to the network just the power cable having the AP in stand alone
Like if you were doing a site survey but in this case i would be using the spectrum monitor to see the 2.4ghz band.
I try doing it but when i change it in one band to spectrum monitor, it change it to the other band as well automatically...
Cheers
CArlos
