Spectrum Monitoring
  • 1.  Spectrum Monitoring
    Posted Nov 21, 2013 09:04 AM
    Recently updated to the new 4.0 firmware and I must say that I really do appreciate the client-match functionality.   One thing that I have noticed is that the "spectrum" tab does not display.  I turn on "background sprectrum monitoring" and then select an appropriate AP but there is no "specturm" tab to select.  Perhaps I am missing something.  Thoughts?
  • 2.  RE: Spectrum Monitoring
    Posted Nov 21, 2013 01:20 PM
    What is the model of the IAP that you are trying to get a spectrum report on?
  • 3.  RE: Spectrum Monitoring
    Posted Nov 21, 2013 01:48 PM
    I am using IAP-105.  I have enabled backgroup spectrum monitoring, but I never see the "spectrum" tab that usually shows up next the the "Monitoring" tab.
  • 4.  RE: Spectrum Monitoring
    Posted Nov 21, 2013 03:02 PM
    Have you clicked on / highlighted the AP first?   Here is my IAP-135 with v.4.0.spectrum.jpg
  • 5.  RE: Spectrum Monitoring
    Posted Nov 21, 2013 04:36 PM
    Yes, I click the appropiate AP but the "Spectrum" button does not appear on the IAP-105....or at least on mine.  I also tried rebooting all the APs just to make sure I didn't need to have this done first after making the setting.  It used to work on the prior version of firmware, but seems to be causing me issues once I have uprgraded.
  • 6.  RE: Spectrum Monitoring
    Posted Jan 06, 2014 10:11 AM
    I have upgraded to 6.3.1.2-4.0.0.2_41506 and still no Spectrum tab even with the option in the RF enabled for background scanning.
  • 7.  RE: Spectrum Monitoring
    Posted Jan 06, 2014 10:34 AM
    Have you tried enabling Spectrum in dedicated mode rather than hybrid / background scanning?
  • 8.  RE: Spectrum Monitoring
    Posted Jan 06, 2014 10:38 AM
    But that will stop serving the clients. And the background Spectrum should present something of the same channel as the radio.
  • 9.  RE: Spectrum Monitoring
    Posted Jan 06, 2014 10:42 AM
    Per the post by background scanning has been removed from the IAP-105 beginning in 4.0.
  • 10.  RE: Spectrum Monitoring
    Posted Jan 06, 2014 10:54 AM
    I just gave a quick search and read to the 4.0 release document and it's not specified the removal of the feature for the iAP105.
  • 11.  RE: Spectrum Monitoring
    Posted Jan 06, 2014 11:48 AM
    Hmm.....you are correct on the ommision. I skimmed through past versions as well and did not see a note.  I will check with Product Management on the Release Notes.
    There was a Field Bulleting describing the issue (attached).
    Attachment(s)
  • 12.  RE: Spectrum Monitoring
    Posted Jan 06, 2014 12:15 PM
    I have already sent the question to the Aruba representitive that handeles our company and I will update the case if there is new information from him.
    Just got a reply that yes it's removed and he will check the reasoning and plans for the future.
  • 13.  RE: Spectrum Monitoring
    Posted Dec 27, 2013 12:59 AM
    Just chiming in and I have iap-105 us version on firmware 6.3.1.1-4.0.0.1_41049 and I can't find that  spectrum button either.  Thanks.....
  • 14.  RE: Spectrum Monitoring
    Posted Jan 02, 2014 10:04 PM
    IAP-105's hybrid Spectrum mode had been removed from 4.0 release.
  • 15.  RE: Spectrum Monitoring
    Posted Jan 02, 2014 11:17 PM
    So if  this (specturm monitoring) has been removed on the IAP-105, am I to assume that the "background spectrum monitoring" option will have no effect if I enable it?
  • 16.  RE: Spectrum Monitoring
    Posted Jan 02, 2014 11:27 PM
    You can use the standalone mode spectrum in per AP setting.
