Speed and Duplex configuration not supported
  • 1.  Speed and Duplex configuration not supported
    Posted Jan 20, 2016 10:28 PM
    Hi Everyone,
    Can you help me fix this essue?
    "Speed and Duplex configuration not supported"
    Model: Aruba 7205
    Version: 6.4.3.4
  • 2.  RE: Speed and Duplex configuration not supported
    Posted Jan 21, 2016 04:46 PM
    From the Aruba 7205 controller installation guide here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=17286
    "10GBASE-X Ports The 7205 controller is equipped with two 10GBASE-X (SFP+) ports (4 and 5). These ports are intended for use with SFP/SFP+ and support dual-speed (1GbE or 10GbE) operation."
    In other words, you cannot configure the duplex on them.
  • 3.  RE: Speed and Duplex configuration not supported
    Posted Jan 22, 2016 09:28 PM
    Thank you Sir Colin Joseph for clarification.
  • 4.  RE: Speed and Duplex configuration not supported
    Posted Jan 21, 2016 10:34 PM
    What type of SFP is in the slot?
    What are you trying to configure it as?
