Technically speaking, HPE OfficeConnect 1910 Switch Series is engineered to support SFP Transceivers listed on its QuickSpecs document [*].
[*] to be clear: that doesn't necessarily mean that only genuine and supported SFP Transceivers work once inserted...but it means that using those ones you will be sure that they work flawlessly and, more important, that the resulting hardware configuration is supported by HPE in case of related HW/SW issues.
