  • 1.  Splash Page
    Posted Jun 10, 2019 04:05 PM
    I have a Aruba 7210-US Version 6.4.4.10.  I'm trying to extract the html file that is used for the captive portal in order to modify it.  Can someone tell me where on the controller I can get that file?
  • 2.  RE: Splash Page
    Posted Jun 11, 2019 04:05 AM
    Please check the ArubaOS manual: https://www.arubanetworks.com/techdocs/ArubaOS_6.4.4.x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Captive_Portal/Internal_Captive_Portal.htm%3FTocPath%3DCaptive%2520Portal%2520Authentication
    If you access the page and save the HTML, then compare that to what is shown in the manual, you should get this done as well.
