Hi
If I order the device for different clients in one order. I can split licenses between them if I have to be ordered separately.
exp. in order 74 x JW472AAE
64 x JW472AAE for the first clients
10 x JW472AAE for the second clients
Best
Krzysiek
Yes, you can.
Hi, during activation ?
This sounds good. Can you please describe what is the process for the split.
Cheers,
LG
What are you trying to do? If you are trying to order two separate licenses at different times, you can do that. Purchase one, apply it. Purchase another one later, and apply it later...
HI.
When I put together a orders for the two controllers, and licensed to them.I received the license which is the sum of the licenses for both controllers. Controllers will work independently so I could do with a single server license. Now I need to activate half of the license on one half of the second. Is there any way to do this?
KK
You cannot activate the same license on two controllers, unfortunately. You should engage your sales contact to get that corrected.EDIT:. If both controllers are on the same routed network, you can set them up for centralized licensing where they can share licensing, however. http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/New_Licenses/Multi__Network.htm?Highlight=Centralized
Sorry for giving you the runaround. If this is two separate customers, you cannot share licenses or do centralized licensing. You need to have your sales order corrected. Please contact the vendor to have this done.
Thanks for your assistance
