last person joined: 11 hours ago
Split Radio
  • 1.  Split Radio
    Posted May 30, 2024 01:00 PM
    Hi there,
    What are the advantages of using Split Radio when using AP 555, vs the regular single 8x8 radio?
    When should I use it or benefit from it?
  • 2.  RE: Split Radio
    Posted May 30, 2024 07:25 PM
    generally in a high density env you can use it to get more clients on separate non-overlapping channels. Also you can use the first 5GHz radio for dedicated mesh link and the other for client access.
