This thread has been viewed 29 times
  • 1.  Split Tunnel
    Posted Nov 21, 2014 05:58 PM
    I followed the guide in my bootcamp manual for setting up a split tunnel SSID, but it is still routing all traffic through the corporate lan instead of routing internet through the local router .  Any help would be appreciated.  I have the following policy rules.  I only have thiss one policy for the role that is assignd to the user.
    IPv4 user ru-lan any permit Low
    IPv4 ru-lan any any permit Low
    IPv4 user any any route src-nat Low
    IPv4 any any svc-dhcp permit
    Eric
  • 2.  RE: Split Tunnel
    Posted Nov 21, 2014 06:50 PM
    - The dhcp rule should be at the top
    - make sure your ap is configured as a rap
    - make sure your virtual ap forwarding mode is split tunnel
    - make sure your user actually is in that role
  • 3.  RE: Split Tunnel
    Posted Nov 21, 2014 09:01 PM
    Thanks for the quick response.  The DHCP rule i actually first....for some reason it pasted differently.  My AP is configured as a RAP.  The mode is slit-tunnel.  The user is assigned the role that has this policy.  Is there something else I'm missing?  Am I supposed to get an IP from the corporate Lan or my local network?
  • 4.  RE: Split Tunnel
    Posted Nov 21, 2014 09:04 PM
    You are supposed to get it from Corporate LAN.
    make your last rule "any any any route src-nat low"
  • 5.  RE: Split Tunnel
    Posted Nov 21, 2014 09:23 PM
    It seems like I did everything I was supposed to.
    (arubahost1) #show rights remote-test-splittunnel
    Derived Role = 'remote-test-splittunnel'
    Position Name Type Location
    1 split-tunnel session
    split-tunnel
    Priority Source Destination Service Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan ClassifyMedia IPv4/6
    1 any any svc-dhcp permit Low 4
    2 user ru-lan any permit Low 4
    3 ru-lan any any permit Low 4
    4 user any any route src-nat Low 4
  • 6.  RE: Split Tunnel
    Posted Nov 21, 2014 09:25 PM
    the only thing now is to confirm that your user is ending up in that role.
  • 7.  RE: Split Tunnel
    Posted Nov 21, 2014 09:28 PM
    I get an IP from my corporate Lan.  But when I traceroute to anything on the internet it goes through the corporate Lan still.
  • 8.  RE: Split Tunnel
    Posted Nov 21, 2014 09:30 PM
    Here is the proof that the user is getting that role.
    (arubahost1) #show user ap-name eric-home
    Users
    IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode Type Host Name
    129.85.53.238 00:24:d6:12:a0:2e eric remote-test-splittunnel 00:00:35 802.1x eric-home Associated(Remote) remote-test-splittunnel/6c:f3:7f:63:69:92/a-HT remote-test-splittunnel-aaa_prof split tunnel Win 7
  • 9.  RE: Split Tunnel
    You need to type "show datapath user ap-name <name of ap> table" to see what ACLs your traffic is hitting.
  • 10.  RE: Split Tunnel
    Posted Nov 21, 2014 09:32 PM
    (arubahost1) #show datapath user ap-name eric-home table
    Datapath User Table Entries
    Flags: P - Permanent, W - WEP, T- TKIP, A - AESCCM, G - AESGCM, V - ProxyArp to/for MN(Visitor),
    N - VPN, L - local, Y - Any IP user, R - Routed user, M - Media Capable,
    S - Src NAT with VLAN IP, E - L2 Enforced, F - IPIP Force Delete, O - VOIP user, I - Interim stats,
    C - Inactive, D - Suppress Idle TMO, m - IP mobile user anchor
    FM(Forward Mode): S - Split, B - Bridge, N - N/A
    IP MAC ACLs Contract Location Age Sessions Flags Vlan FM IdleTMO
    192.168.11.1 6C:F3:7F:CE:36:98 2700/0 0/0 0 482 0/65535 P 4095 N 300
    10.1.1.204 6C:F3:7F:CE:36:98 2700/0 0/0 0 0 1/65535 P 1 N 300
    10.1.1.209 20:02:AF:3A:60:D5 59/0 0/0 0 0 6/65535 1 B 300
    129.85.53.238 00:24:D6:12:A0:2E 71/0 0/0 0 0 22/65535 53 S 300
    10.9.4.6 00:1A:1E:01:50:80 2703/0 0/0 0 482 0/65535 P 0 N 300
    0.0.0.0 00:24:D6:12:A0:2E 71/0 0/0 0 0 0/65535 P 53 S 300
    0.0.0.0 20:02:AF:3A:60:D5 59/0 0/0 0 0 6/65535 1 B 300
  • 11.  RE: Split Tunnel
    Posted Nov 21, 2014 09:35 PM
    The IP is 129.85.53.238.  It i hitting ACL 71, which is mapped to the policy i showed before.
  • 12.  RE: Split Tunnel
    Posted Nov 21, 2014 09:36 PM
    The line with your client has port 53 (DNS) split tunneled, like it should be:
    129.85.53.238 00:246:12:A0:2E 71/0 0/0 0 0 22/65535 53 S 300
     Pass some actual traffic and excute:
    show datapath user ap-name eric-home table 129.85.53.238
     What gets tunneled and what gets sent back is determined by your destination ru-lan.  What is that defined as?
  • 13.  RE: Split Tunnel
    Posted Nov 21, 2014 09:41 PM
    That 53 is the vlan, not DNS.  And RU-LAN is defined as my whole corporate ip space....129.85.0.0/16.  So any trafice destined for the internet should go through my local router.  But its not.  I ran that command but it doesnt take the IP addres after table.
  • 14.  RE: Split Tunnel
    Posted Nov 21, 2014 09:48 PM
    Maybe this helps.
    (arubahost1) #show datapath session ap-name eric-home table 129.85.53.238
    Q - Real-Time Quality analysis
    E - Media Deep Inspect, G - media signal
    RAP Flags: 1 - Class 1, 2 - Class 2, 3 - Class 3
    Source IP Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Packets Bytes Flags
    108.160.163.97 129.85.53.238 6 80 54393 0 0 0 1 dev17 11c 0 0 F
    108.160.163.97 129.85.53.238 6 80 54395 0 0 0 1 dev17 57 0 0
    129.85.53.238 10.9.4.8 6 53917 22 0 0 0 0 dev17 380b 0 0 C
    129.85.53.238 74.125.22.188 6 53849 443 0 0 0 1 dev17 3e0b 0 0 C
    74.125.22.188 129.85.53.238 6 443 53849 0 0 0 1 dev17 3e0b 0 0
    74.125.226.85 129.85.53.238 6 443 53844 0 0 0 0 dev17 3e13 0 0
    129.85.53.238 192.96.201.129 6 53848 5938 0 0 0 0 dev17 3e0e 0 0 C
    129.85.53.238 108.160.163.97 6 54395 80 0 0 0 1 dev17 57 0 0 CI
    129.85.53.238 108.160.163.97 6 54393 80 0 0 0 1 dev17 11c 0 0 FCI
    192.96.201.129 129.85.53.238 6 5938 53848 0 0 0 0 dev17 3e0e 0 0
    129.85.53.238 74.125.226.73 6 54053 443 0 0 0 1 dev17 1df1 0 0 C
    129.85.53.238 74.125.226.69 6 54128 443 0 0 0 2 dev17 12a4 0 0 C
    129.85.53.238 173.194.123.34 6 54046 80 0 0 0 2 dev17 1e24 0 0 CI
    24.143.204.35 129.85.53.238 6 80 54371 0 0 0 2 dev17 31f 0 0
    129.85.53.238 74.125.226.85 6 53844 443 0 0 0 1 dev17 3e13 0 0 C
    74.125.226.69 129.85.53.238 6 443 54128 0 0 0 2 dev17 12a4 0 0
    64.233.171.189 129.85.53.238 6 443 54182 0 0 0 2 dev17 108b 0 0
    74.125.226.73 129.85.53.238 6 443 54053 0 0 0 1 dev17 1df1 0 0
    129.85.53.238 173.192.82.196 6 53877 80 0 0 0 1 dev17 3bbe 0 0 CI
    129.85.53.255 129.85.53.238 17 17500 17500 0 0 0 1 dev17 15 0 0 FY
  • 15.  RE: Split Tunnel
    Posted Nov 21, 2014 10:02 PM
    There is no "s" flag, so it is not hitting the route source-nat acl
    Here is what we have in production:
    any     internal-nets        any          permit
  • 16.  RE: Split Tunnel
    Posted Nov 21, 2014 10:14 PM
    That did the trick.  Apparently, the suggestion I got was not good then.  It seems you cant use the "user" as the source or else it doesnt work right.  Thanks a bunch for helping me sort this out.
    Eric
