I had configured Remote AP, and used the Split Tunnel mode on the Captive-Portal SSID, It works with VLAN that attached with the Controller, and I have some questions. Can I use the VLAN on the remote site?
I place the RAP on the Branch
Controller ---- WAN Link ---- RAP (Remote Site, Branch)
Controller's VLAN : 10,20,30
Branch's VLAN : 40
SSID : Captive-Portal-SSID (VLAN10)
and is it possible to change the VLAN Captive-Portal-SSID to VLAN40?
Is it works only with the VLAN on controller?
