split tunnel on wired port
  • 1.  split tunnel on wired port
    Posted Mar 13, 2012 11:05 AM
    Hi
    im trying to configure a wired port to split tunnel the traffic. Is there a best practice guide to follow in this case?
    I also want to change the role when connecting as a wired client, i dont want to use the "authenticated" role in this case
    regards
    Carlos
  • 2.  RE: split tunnel on wired port
    Posted Mar 13, 2012 11:11 AM
    Is this for a remote access point, aka RAP?
  • 3.  RE: split tunnel on wired port
    Posted Mar 13, 2012 11:22 AM
    Download the Virtual Branch Network VRD from the link below and go to page#159 - Task 6 - Configure Wired AP and Wired Port Profiles
    http://www.arubanetworks.com/pdf/technology/VBN_VRD.pdf
    Hope it helps !
    HT
  • 4.  RE: split tunnel on wired port
    Posted Mar 13, 2012 10:03 PM
    Try something like this, but do read the VRDs too...
    ap wired-ap-profile "split-tunnel-port"
    wired-ap-enable forward-mode split-tunnel
    switchport access vlan x
    ap wired-port-profile "split-tunnel-port-rules"
    aaa-profile "ROLE-WITH-SPLIT-TUNNEL-RULES"
    ap-group "YOUR-GROUP"
    enet1-port-profile "split-tunnel-port-rules"
    The bits in capitals obviously you need to work out!
