Thanks for your reply. I've tried this:
1: tried from different machines (all windows OS'es however) with bitvise or putty, from different subnets
2: once your're in, you stay in until the idle timer runs out; no disconnects before that. then sometimes you can connect again but mostly the issue returns
3: i have a serial connection to one of the switches now, when I try to access another one from there:
Aruba8320-DC1-1# ping aruba8320-dc1-2
PING aruba8320-dc1-2.<domain> (192.168.255.42) 100(128) bytes of data.
108 bytes from 192.168.255.42: icmp_seq=1 ttl=64 time=0.215 ms
108 bytes from 192.168.255.42: icmp_seq=2 ttl=64 time=0.257 ms
108 bytes from 192.168.255.42: icmp_seq=3 ttl=64 time=0.250 ms
108 bytes from 192.168.255.42: icmp_seq=4 ttl=64 time=0.255 ms
108 bytes from 192.168.255.42: icmp_seq=5 ttl=64 time=0.269 ms
--- aruba8320-dc1-2.<domain> ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4076ms
rtt min/avg/max/mdev = 0.215/0.249/0.269/0.020 ms
Aruba8320-DC1-1# ssh aruba8320-dc1-2
kex_exchange_identification: read: Connection reset by peer
Aruba8320-DC1-1# ssh 192.168.255.42
Kind regards
Kris Vervisch
Original Message:
Sent: Feb 03, 2021 08:00 AM
Subject: SSH connection abort
We have a similar setup and use local/remote ssh extensively.
Disclaimer: I am an aoscx noob.
Forcing different symptoms to cause us to think out of the box:
1. Try another remote client and OS to see if SSH break symptoms are identical.
2. If your customer has the knowledge, have them locally SSH to one of the 8320's and try to force a prolonged SSH session.
3. If you SSH to one 8320 and then from the first 8320, SSH to a second 8320, do any of the connections break in a similar manner?
R-Air
Original Message:
Sent: Feb 02, 2021 04:09 AM
Good morning,
We have 4 new Arubaos-cx 8320 switches at a customer site where we are no longer able to connect via SSH. With Putty we get the error "Network error: Software caused connection abort", with Bitvise we see "The SSH session has terminated with error. Reason: FlowSocketReader: Error receiving bytes. Windows error 10054: An existing connection was forcibly closed by the remote host."
Rebooting the switch helps for a few hours;
Accessing the switch via serial and executing no ssh server vrf default and ssh server vrf default <sometimes> helps, for a few hours.
But always the problem returns. Debug sshutils all on the switch doesn't show any entries when trying to connect.
OS version is TL.10.06.0010
Keep in mind that we want as little fuzz as possible with with certificate generation and all that, certificates always like to expire at the worst possible time. We just want to connect to the switch.
Has anybody had this issue or any ideas to keep ssh working?
Thank you,
Kris
Kris
