SSH Enable password
This thread has been viewed 30 times
  • 1.  SSH Enable password
    Posted Jan 16, 2013 10:31 AM
    When trying to get to enable mode on a 3200 controller I am prompted for a password which I never set. Is there a way around this? How can you set the ssh enable password via CLI? WEBGUI?
    thx
    #3200
  • 2.  RE: SSH Enable password
    Posted Jan 16, 2013 10:47 AM
    Probably the default password is "admin" or "enable".
    You can set it with the following command:
    conf t
    enable secret
    (first you need to enter the enable password to get privileged access)
  • 3.  RE: SSH Enable password
    Posted Jan 16, 2013 10:41 PM
    To reset the enable password if you don't know it; you'll need console access to the controller and follow these steps:
    User: password
    Password: forgetme!
    (aruba) >enable
    Password: enable
    (aruba) #exit
    (aruba) >exit
    Log back in as your normal admin account and test that the enable password is reset to enable.  You can then use the "enable secret" command to set it to something you want:
    (aruba) #configure terminal
    Enter Configuration commands, one per line. End with CNTL/Z
    (aruba) (config) #enable secret
    Password: <new enable password>
    Re-Type password: <new enable password>
    (aruba) (config) #write memory
    You can use this same procedure to reset the root admin password as well.  To do so, you'd run the following:
    User: password
    Password: forgetme!
    (aruba) >enable
    Password: enable
    (aruba) (config) #mgmt-user admin root
    Password: <new admin password>
    Re-Type password: <new admin password>
    (aruba) (config) #exit
    (aruba) #exit
    (aruba) >exit
  • 4.  RE: SSH Enable password
    Posted Jan 17, 2013 10:22 AM
    I will go to the site and console into the controller to reset the password
    thx
  • 5.  RE: SSH Enable password
    Posted Apr 23, 2018 02:31 PM
    Well, easiest way that I've found so far is to go into Controller Wizard. It will allow you to change the enable password.
