SSH to an IAP via script
This thread has been viewed 16 times
  • 1.  SSH to an IAP via script
    Posted Feb 01, 2021 09:44 AM
    I wanted to see if anyone has a working example of a pythion script that can connect to an IAP cluster and execute basic commands.
    SATX71
  • 2.  RE: SSH to an IAP via script
    Posted Feb 02, 2021 04:35 AM
    Not sure what you are trying to achieve, but you may have a look at Airrecorder.
    And not python, but Expect (which has a Python module as well, so you may use it to convert into python), this is a script that logs in over ssh, checks if a client is connected to the AP, and if it is it will disconnect the client, just as an example:
    #!/usr/bin/expect -f
    set timeout 20
    set ip [lindex $argv 0]
    spawn ssh admin@$ip
    expect "password:"
    send -- "ThePassword-here\r"
    expect "#"
    send -- "show clients | inc b8:27:eb:01:3a:ff\r"
    expect {
       "rpi-client" {
          send -- "disconnect-user mac b8:27:eb:01:3a:ff\r"
          send -- "\r"
    expect "#"
    send -- "exit"
    Note that scripting over SSH is not really recommended as the CLI commands or command output may change over time. Sometimes it is just a pragmatic and quick, so from that points valid approach to fix an immediate issue.
  • 3.  RE: SSH to an IAP via script
    Posted Feb 06, 2021 07:50 AM
    did you look at netmiko?
    https://github.com/ktbyers/netmiko
    It is written in python and can work with many network vendors. I think IAP's are currently not there, but from my point of view, it should still work.
    BR
    Florian
    Florian Baaske
    Also visit the AirHeads Youtube Channel:
    https://www.youtube.com/channel/UCFJCnuXFGfEbwEzfcgU_ERQ
    Feel free to visit my personal Blog
    https://www.flomain.de
  • 4.  RE: SSH to an IAP via script
    Posted Feb 25, 2021 01:01 PM
    Thanks guys. Sorry for the last response. I was able to get it working using NetMiko. I didn't realize it would work with Aruba equipment. We aren't allowed to have JRE on our systems here so Air Recorder is not an option unfortunately.
    Chris Watson
