SSH to Controllers, problem with encryption?
  • 1.  SSH to Controllers, problem with encryption?
    Posted Oct 02, 2012 08:10 AM
    I can use freely available code to connect to SSH appliances, like NetApp.
    But I am struggling to get a connection to the Aruba controllers.
    [I'm using C# and the Tamir SharpSSH library]
    Here is an excerpt from Putty, detailing the differences.
    (Has anyone else overcome this problem? Or can offer some advice?)
    I wonder of the Library can't handle SHA 256, or AES 256.
    Can those be adjusted on the Aruba controller?
    Any help appreciated though, thanks.
    NetApp, works
    2012-09-27 18:07:23 Looking up host "nas0001"
    2012-09-27 18:07:23 Connecting to 172.16.0.200 port 22
    2012-09-27 18:07:23 Server version: SSH-2.0-OpenSSH_3.4p1
    2012-09-27 18:07:23 We claim version: SSH-2.0-PuTTY_Release_0.60
    2012-09-27 18:07:23 Using SSH protocol version 2
    2012-09-27 18:07:24 Using Diffie-Hellman with standard group "group1"
    2012-09-27 18:07:24 Doing Diffie-Hellman key exchange with hash SHA-1
    2012-09-27 18:07:24 Host key fingerprint is:
    2012-09-27 18:07:24 ssh-rsa 768 <removed>
    2012-09-27 18:07:24 Initialised triple-DES CBC client->server encryption
    2012-09-27 18:07:24 Initialised HMAC-SHA1 client->server MAC algorithm
    Aruba, fails
    2012-09-27 18:08:19 Looking up host "aru0001"
    2012-09-27 18:08:19 Connecting to 172.16.12.1 port 22
    2012-09-27 18:08:19 Server version: SSH-2.0-OpenSSH_4.6
    2012-09-27 18:08:19 We claim version: SSH-2.0-PuTTY_Release_0.60
    2012-09-27 18:08:19 Using SSH protocol version 2
    2012-09-27 18:08:19 Doing Diffie-Hellman group exchange
    2012-09-27 18:08:19 Doing Diffie-Hellman key exchange with hash SHA-256
    2012-09-27 18:08:19 Host key fingerprint is:
    2012-09-27 18:08:19 ssh-rsa 2048 <removed>
    2012-09-27 18:08:19 Initialised AES-256 SDCTR client->server encryption
    2012-09-27 18:08:19 Initialised HMAC-SHA1 client->server MAC algorithm
  • 2.  RE: SSH to Controllers, problem with encryption?
    Posted Oct 02, 2012 10:18 AM
    hi tammi,
    are trying to connect to Aruba Controller using Putty SSH ?
    and it failed ?
    what appear on screen once you enter MC IP and start using SSH ?
    did you tried to use Telnet or SSHv1 (did it work or not)?
    are you trying to get access from wireless or using wire ?
    can you verify the Controller configuration ?
  • 3.  RE: SSH to Controllers, problem with encryption?
    Posted Oct 02, 2012 11:56 AM
    I am connecting programmatically.
    I resolved the issues though. Basically, the Tamir OpenSSH library cannot use:  AES-256 SDCTR
    So I switched my code to Renci SSH.Net library, and now I can add RAP configuration to my controllers with a Windows GUI.
    This means our site engineers can provision and install RAPs themselves without have an admin account on the wireless controller.
    (And they don't have to wait for a super-admin(tm) just to install an AP!)
