SSH to RAP-3?
  • 1.  SSH to RAP-3?
    Posted Sep 18, 2012 01:50 PM
    Is it possible to enable SSH on my RAP-3 that operates the Instant network? I can see it on the network.
    Nmap scan report for 192.168.104.242
    Host is up (0.010s latency).
    Not shown: 995 closed ports
    PORT     STATE SERVICE
    80/tcp   open  http
    443/tcp  open  https
    4343/tcp open  unicall
    8080/tcp open  http-proxy
    8081/tcp open  blackice-icecap
  • 2.  RE: SSH to RAP-3?
    Posted Sep 18, 2012 02:32 PM
    You cannot SSH into the RAP-3 that is working as an Instant AP but you can telnet into it.
    Telnet is disabled by default, and you can enable it from the web UI of the Virtual controller.
    Here is a KB to enable telnet on IAP.
    https://kb.arubanetworks.com/app/answers/detail/a_id/1490/kw/enable%20telnet
  • 3.  RE: SSH to RAP-3?
    Posted Sep 18, 2012 02:42 PM
    Thanks HT - I'm getting used to the UI now :)
    The option has moved though and should be updated in the KB. It's under Settings >> Show Advanced Options >> General
    (there should be an image here)
    Terminal Access Setting Moved
    That seems to work. Here are some telnet results:
    00:1a:1e:08:59:79# show ip interface brief
    Interface                   IP Address / IP Netmask            Admin   Protocol
    br0                         192.168.104.242 / 255.255.0.0      up      up
    00:1a:1e:08:59:79#
  • 4.  RE: SSH to RAP-3?
    Posted Sep 18, 2012 04:45 PM
    Thank you for the feedback. We shall update the KB asap.
