SSID Creation Error - Illegal Character
  • 1.  SSID Creation Error - Illegal Character
    Posted Aug 04, 2014 12:46 PM
    I just began a small project to replace a some Ubiuqiti AP's with Aruba IAP 225's. The problem I'm having is with SSID creation. Currently, the production network SSID contains an apostrphie (') in the SSID name. It seems Aruba is deeming this as an illegal character (though this also works fine with our Meraki's). I would really like to avoid throwing out the apostrophie as it will require a lot of changes to our production systems.
    Is there any way around this limitation? CLI perhas?
    Thanks in advance!
    #AP225
  • 2.  RE: SSID Creation Error - Illegal Character
    Posted Aug 04, 2014 01:15 PM
    You have to created thru the CLI
    IAP (SSID Profile "lab_ssid's") # essid lab_guest's
    IAP(SSID Profile "lab_ssid's") #
    show networks
    Networks
    Key Name Clients Type Band Authentication Method Key Management IP Assignment Status Zone
    lab_guest's lab_guest's 0 employee all None None Default VLAN Enabled -
  • 3.  RE: SSID Creation Error - Illegal Character
    Posted Aug 04, 2014 01:26 PM
    Once it has been created, can it then be managed through the GUI?
  • 4.  RE: SSID Creation Error - Illegal Character
    Posted Aug 04, 2014 01:48 PM
    Yes
  • 5.  RE: SSID Creation Error - Illegal Character
    Posted Aug 11, 2014 11:06 PM
    I'm just getting around to testing this out.. Can anyone point me to some walkthrough documentation on the CLI? -- The Reference Guide is horrendously organized for learning simple management tasks.
    I can't figure out how to select the SSID profile..
  • 6.  RE: SSID Creation Error - Illegal Character
    Posted Aug 11, 2014 11:26 PM
    So I actually figured out how to do this in the CLI but it seems the CLI won't allow a space in the SSID.
    So I can either use the GUI to add in SSID spacing or I can use the CLI to add the apostrophie but not no spaces.
    If this is indeed the case, this is kind of poor of Aruba to leave out such common functionality.
    Does anyone have any solutions to this?
