  • 1.  SSID down
    Posted Jul 31, 2018 05:33 AM
    I have a customer who has reported that for a period of around an hour their devices were unable to connect to an SSID - they were unable to say if the SSID was being broadcast at the time as no one technical was available to troubleshoot.
    Running the show ap bss-table command on the controllers shows that the SSID  has a time under the TOT-T column that equates to when it started working again (hours). The other SSIDs on the same APs have a much longer time next to them (days).
    They have Airwave and the radio errors graph for one of the APs show a gap at around 18:00 which was the time reported as the fault occuring (see attachment).
    The log on the controller doesn't show anything unusual around this period and I am wondering if Airwave could supply any more info in this regard. I've not used Airwave enough to be certain here - any suggestion to interrogate Airwave for why the SSID may have been down?
  • 2.  RE: SSID down
    Posted Jul 31, 2018 05:40 AM
    I made an error when checking things out it looks like all SSIDs went down on the APs so I'm going to investigate this further - the AP has remained up though.
  • 3.  RE: SSID down
    Posted Aug 01, 2018 04:15 AM
    Hi!
    Is this a controller based setup? Could something have prevented the communication between the APs and the controller during this time? Perhaps a WAN link or a firewall in between?
    Cheers,
  • 4.  RE: SSID down
    Posted Aug 01, 2018 04:27 AM
    Hi Christoffer, yes I've told the customer to investigate a simple connectivity issue. I'd originally thought it was only a single SSID but with so many APs and SSIDs I'd made a mistake and wasn't sure what the cause might be.
