SSID for CORPORATE with no PUBLIC Access via Central
  • 1.  SSID for CORPORATE with no PUBLIC Access via Central
    Posted Jul 24, 2016 10:10 PM
    Greetings,
         Sorry for the newbie question but i'm having confusion on config.
        I' m trying to simulate 3 SSIDs via Aruba Central (a) Corporate with public access, (b) Guest with public access, (c) Corporate with no public access * which im having difficulty in getting IP address whenever user connects *.
    on (a), i used "network assigned" to provide I.P address separate DHCP(internal), while I used "virtual controller assigned" on guest which is also working. On 3rd SSID, please see result of attempts below:
    1st attempt:
    employee>network assigned>passphrase> allow any to 172.16.0.0(internal network) and deny to all destination
    --still user can't get any I.P and access on internal network.
    2nd attempt.
    employee>virtual contrller assigned>passphrase>deny any except to 172.16.0.0
    seems basic but what could be the best access policy for this?
    any suggestions will be greatly appreaciated. thank you :)
  • 2.  RE: SSID for CORPORATE with no PUBLIC Access via Central
    Posted Jul 25, 2016 03:20 AM
    What type of DHCP are you using for the 3rd SSID? You don't seem to specify that.
    Have you tried adding a rule allowing DHCP client traffic to any range? See if it makes a difference. If it does, try making a packet capture of the DHCP protocol and see which address is answering. If it doesn't, check firewall to dhcp server or see configuration of scope.
    Kind regards,
    jcelis
  • 3.  RE: SSID for CORPORATE with no PUBLIC Access via Central
    Posted Jul 25, 2016 03:50 AM
    thank you for your response jcelis.
        I used "network assigned" on 3rd SSID(same on 1st SSID), I also tried using virtual-controller(hoping user can get an I.P even from IAP itself) while modifying the network access policy like deny all except to a network 172.16.0.0 but still no good.
      As per  DHCP, 3rd and 1st SSIDs get their IPs from a same DHCP scope from an external server since it's network assigned while trying to block the public access of 3rd SSID thru applying network based access rules from Central/IAP side.
  • 4.  RE: SSID for CORPORATE with no PUBLIC Access via Central
    Posted Jul 25, 2016 04:11 AM
    Ok, try allowing dhcp traffic to any destination and put it first.
    something like:
    user any udp 68  deny (blocking user as dhcp server)
    user any svc-dhcp allow
  • 5.  RE: SSID for CORPORATE with no PUBLIC Access via Central
    Posted Jul 25, 2016 04:29 AM
    are those policies can be implement here in central?
  • 6.  RE: SSID for CORPORATE with no PUBLIC Access via Central
    Posted Jul 25, 2016 04:55 AM
    Yes, they should be in the ACL list for that SSID.
