Ssid guest configured on aruba 650 not erasable or editable by wizard
  • 1.  Ssid guest configured on aruba 650 not erasable or editable by wizard
    Posted Jun 12, 2014 10:41 AM
    Hi there,
    In controller 650 i have 2 ssid (corporate , guest).
    when i try to modify ssid  guest by wizard, system say me "impossible change parameter from wizard".
    The name "guest"  in ssid's table is in light gray  while "corporate" is typed in black.
    How can i do to erase this ssid by GUI or by consolle?
    Thanx in advance.
  • 2.  RE: Ssid guest configured on aruba 650 not erasable or editable by wizard
    Posted Jun 12, 2014 11:22 AM
    Navigate to the AP group you created, under virtual AP -> SSID profile, you can change it there.
  • 3.  RE: Ssid guest configured on aruba 650 not erasable or editable by wizard
    Posted Jun 12, 2014 12:09 PM
    Hi Pasquale,
    how did it happen?
    Thanx again
  • 4.  RE: Ssid guest configured on aruba 650 not erasable or editable by wizard
    Posted Jun 12, 2014 12:27 PM
    How did what happen?
    I assume through the wizard it will not let you modify it, hence you must manually adjust it within the profile
