Cloud Managed Networks
ssid name change
  • 1.  ssid name change
    Posted Feb 08, 2018 04:54 PM
    how to change SSID name?
    I tried using ESSID config but the portal does not allow to modify.
    any other way?
  • 2.  RE: ssid name change
    Posted Feb 08, 2018 09:02 PM
    Hi Adolfo,
    Please share a screenshot for the steps you tried for changing the SSID.
  • 3.  RE: ssid name change
    Posted Feb 09, 2018 12:31 PM
    sure, there is attached the screens i tried to flollow.
    thanks for your answer
    Attachment(s)
    docx
    Goal ssid change.docx   1.46 MB 1 version
  • 4.  RE: ssid name change
    Posted Feb 11, 2018 01:46 AM
    It looks like you're doing things the right way...
    Just to discard any possible browser cache issues, I'd try to do the same from an incognito/private window.
    If that still doesn't help please open a TAC case to get it checked.
  • 5.  RE: ssid name change
    Posted Feb 12, 2018 02:37 AM
    Please click on the "Configuration Audit" option on the LHS & see if there are any overrides that might be preventing the configuration to get pushed.
  • 6.  RE: ssid name change
    Posted Feb 12, 2018 11:10 AM
    nothing. it is the first place i checked for some insight for troubleshotting.
    today it works.
  • 7.  RE: ssid name change
    Posted Feb 12, 2018 11:27 AM
    it appears this kind of config only will be made on groups configuration and not over a single VC or ap.
    that makes sense.
    i suggest a error popup if this config will be attempted from the situations mentioned before.
  • 8.  RE: ssid name change
    Posted Feb 12, 2018 03:59 PM
    I just checked this in lab and i am able to change the ESSID on a group level and as well as per IAP level.
    Are you using 6.5.4.4?
  • 9.  RE: ssid name change
    Posted Feb 13, 2018 10:49 AM
    yep 6.5.4.4_62887
    i will do further test.
  • 10.  RE: ssid name change
    Posted Feb 13, 2018 01:42 PM
    it is not possible to do at the VC level
