SSID not broadcasting
This thread has been viewed 44 times
  • 1.  SSID not broadcasting
    Posted Apr 25, 2014 12:07 PM
    i have an aruba 650 and configured for my LAN users to autenticate via domain ,
    i did "aaa test-server mschapv2 nps" and authentication was successful.
    my problem is that my SSID is not broadcasted though i have done all configurations
    on the controller and WLAN lan is seen on the GUI
    i post output of sh ap database
    AP_In_Procurement Office Test 105 192.168.1.127 Up 1m:48s 2 192.168.0.237 0.0.0.0
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
    I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
    X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
    R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
    c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
    u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
    M = Mesh node; Y = Mesh Recovery
    Total APs:1
    it shows 2 in the flags column , some1 help.
  • 2.  RE: SSID not broadcasting
    Posted Apr 25, 2014 12:54 PM
    can you include the full output of "show ap database long" to verify what AP Group the AP is in
    Also, can you verify the following:
    show ap bss-table
    show ap-group <NameofAPGroup>  .....check if a virtual AP is present; if so, run:
    show wlan virtual-ap <NameofVAP> .....check for SSID Profile name
    show wlan ssid-profile <NameofSSIDProfile>  ......check for Hide SSID and Deny_Broadcast Probes fields
  • 3.  RE: SSID not broadcasting
    Posted Apr 25, 2014 01:03 PM
    hers is the output
    (Aruba650) #show ap database long
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP Wired MAC Address Serial # Port FQLN Outer IP User
    AP_In_Procurement Office Test 105 192.168.1.127 Up 1m:19s 2 192.168.0.237 0.0.0.0 d8:c7:c8:ca:cc:b2 BE0223359 1/2 N/A N/A
    Total APs:1
  • 4.  RE: SSID not broadcasting
    Posted Apr 25, 2014 02:18 PM
    What about the other commands above:
    show ap bss-table ap-name "AP_In_Procurement Office"
    show ap-group Test  .....check if a virtual AP is present; if so, run:
  • 5.  RE: SSID not broadcasting
    Posted Apr 25, 2014 04:47 PM
    Do you have any vlan settings?  If not, this would keep the SSID from not broadcasting.  Also, check in your VAP profile that the "Virtual AP Enabled" checkbox is checked(GUI) or enabled.
    Matt
  • 6.  RE: SSID not broadcasting
    Posted Apr 25, 2014 06:57 PM
    Also, check the following to see if there are any errors preventing it from coming up:  show profile-errors.
  • 7.  RE: SSID not broadcasting
    Posted Apr 26, 2014 07:28 AM
    Please check this settings.
