SSID not broadcasting any more!
  • 1.  SSID not broadcasting any more!
    Posted Feb 10, 2012 12:06 AM
    I have a 4504 controller with 5.0.3.3 code and the SSID has stopped broadcasting all of a sudden! I have a bunch of remote APs on it and they are able to connnect just fine. I've checked the VAP profile and it's enabled as well as the SSID which is also enabled. The AP group is also correctly associated with the VAP profile. I have no idea why it's behaving this way. The only thing I can see that's amiss in the logs is:
    Feb 9 14:12:20 :275124:  <ERRS> |fpapps|  XSec Vlan Interface 32 not found line 877
    Anyone experienced something similar
  • 2.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 08:54 AM
    Those messages are cosmetic.
    Type "show profile errors" or "show ap bss-table" to see what you are working with.
  • 3.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 10:58 AM
    There are no profile errors:
    (Controller) #show profile-errors
    Invalid Profiles
    Profile  Error
    (Controller1) #show ap bss-table
    fm (forward mode): T-Tunnel, S-Split, D-Decrypt Tunnel, B-Bridge (s-standard, p-persistent, b-backup, a-always)
    Alcatel-Lucent AP BSS Table
    bss                ess  s/p  ip       phy  type  ch/EIRP/max-EIRP  cur-cl  ap name            in-t(s)  tot-t        mtu   acl-state  acl  fm
    00:24:6c:c2:68:fd  N/A  1/0  5.5.5.5  e1   N/A   N/A               N/A     00:24:6c:c2:68:fc  0        15h:19m:54s  1200  N/A        1    T
    00:24:6c:c2:71:2a  N/A  1/0  5.5.5.3  e1   N/A   N/A               N/A     00:24:6c:c2:71:29  0        15h:20m:6s   1200  N/A        1    T
    00:24:6c:c2:69:01  N/A  1/0  5.5.5.1  e1   N/A   N/A               N/A     00:24:6c:c2:69:00  0        15h:20m:0s   1200  N/A        1    T
    00:24:6c:c2:61:bd  N/A  1/0  5.5.5.8  e1   N/A   N/A               N/A     00:24:6c:c2:61:bc  0        13h:6m:25s   1200  N/A        1    T
    00:24:6c:c2:69:49  N/A  1/0  5.5.5.7  e1   N/A   N/A               N/A     00:24:6c:c2:69:48  0        15h:19m:54s  1200  N/A        1    T
    00:24:6c:c2:71:09  N/A  1/0  5.5.5.4  e1   N/A   N/A               N/A     00:24:6c:c2:71:08  0        15h:19m:55s  1200  N/A        1    T
    00:24:6c:c2:71:0c  N/A  1/0  5.5.5.2  e1   N/A   N/A               N/A     00:24:6c:c2:71:0b  0        15h:20m:0s   1200  N/A        1    T
  • 4.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 11:13 AM
    Looks like you don't have any Virtual APs in ap-groups
  • 5.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 11:21 AM
    But I do, that's amongst the first things I checked. I re-assigned them the VAP and even re-provisioned the APs but no luck.
    (Controller)#show ap-group RAP-2WG
    AP group "RAP-2WG"
    Parameter                                Value
    Virtual AP                               TEST-VAP_prof
    802.11a radio profile                    default
    802.11g radio profile                    default
    Ethernet interface 0 port configuration  default
    Ethernet interface 1 port configuration  default
    Ethernet interface 2 port configuration  default
    Ethernet interface 3 port configuration  shutdown
    Ethernet interface 4 port configuration  shutdown
    AP system profile                        TEST-SYS
    VoIP Call Admission Control profile      default
    802.11a Traffic Management profile       N/A
    802.11g Traffic Management profile       N/A
    Regulatory Domain profile                default
    RF Optimization profile                  default
    RF Event Thresholds profile              default
    IDS profile                              ids-low-setting
    Mesh Radio profile                       default
    Mesh Cluster profile                     N/A
    Provisioning profile                     N/A
    AP authorization profile                 default
  • 6.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 11:43 AM
    Use the "show ap debug received-config ap-name <name of ap>" command to find out why each AP is doing what it is doing.
  • 7.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 11:51 AM
    That doesn't show anything:
    (Controller) #show ap debug received-config ap-name 00:24:6c:c2:61:bc
  • 8.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 11:55 AM
    Is that virtual AP enabled?  Type "show audit-trail" to find out what you changed to possibly find out what you did.
  • 9.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 11:59 AM
    The virtual-AP is indeed enabled. I haven't changed anything in the controller. This just happened when one of the RAP users just reported to me that he wasn't able to see the SSID any more.
    (Controller) #show wlan virtual-ap TEST-vap_prof
    Virtual AP profile "TEST-vap_prof"
    Parameter                                       Value
    Virtual AP enable                               Enabled
    Allowed band                                    all
    AAA Profile                                     TEST-aaa_prof
    802.11K Profile                                 default
    SSID Profile                                    TEST-ssid_prof
    VLAN                                            VLAN_12
    Forward mode                                    tunnel
    Deny time range                                 N/A
    Mobile IP                                       Enabled
    HA Discovery on-association                     Disabled
    DoS Prevention                                  Disabled
    Station Blacklisting                            Enabled
    Blacklist Time                                  3600 sec
    Dynamic Multicast Optimization (DMO)            Disabled
    Dynamic Multicast Optimization (DMO) Threshold  6
    Authentication Failure Blacklist Time           3600 sec
    Multi Association                               Disabled
    Strict Compliance                               Disabled
    VLAN Mobility                                   Disabled
    Remote-AP Operation                             standard
    Drop Broadcast and Multicast                    Disabled
    Convert Broadcast ARP requests to unicast       Enabled
    Band Steering                                   Disabled
    Steering Mode                                   prefer-5ghz
    VLAN POOL SIZE                                  0
    WMM Traffic Management Profile                  N/A
  • 10.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 12:02 PM
    Type "show ap active" and see if the radios are on.  Please also try "show audit-trail" to see if anything has been changed.
  • 11.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 12:20 PM
    (Controller) #show ap active
    Active AP Table
    Name               Group         IP Address  11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP  AP Type     Flags  Uptime        Outer IP
    00:24:6c:c2:61:bc  RAP-2WG  1.1.1.9     0                                 0                                 OAW-RAP2WG  RE     1h:0m:58s     98.220.31.107
    00:24:6c:c2:68:fc  RAP-2WG  1.1.1.10    0                                 0                                 OAW-RAP2WG  RE     1h:0m:57s     76.172.121.69
    00:24:6c:c2:69:48  RAP-2WG  1.1.1.11    0                                 0                                 OAW-RAP2WG  RE     1h:0m:54s     67.173.14.235
    00:24:6c:c2:69:00  RAP-2WG  1.1.1.12    0                                 0                                 OAW-RAP2WG  RE     1h:0m:56s     108.123.68.253
    00:24:6c:c2:71:08  RAP-2WG  1.1.1.13    0                                 0                                 OAW-RAP2WG  RE     1h:0m:54s     99.119.115.43
    00:24:6c:c2:71:29  RAP-2WG  1.1.1.14    0                                 0                                 OAW-RAP2WG  RE     1h:0m:53s     50.90.67.13
  • 12.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 12:15 PM
    Please check
    "show rf dot11g-radio-profile default"
    "show rf dot11a-radio-profile default"
    Check the first two parameters
    Radio enable -- should be "enable"
    Mode  - should say "ap-mode"
  • 13.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 01:09 PM
    Yup. Check the radio profile.
  • 14.  RE: SSID not broadcasting any more!
    Posted Feb 10, 2012 02:28 PM
    D'oh! That was it! How it got disabled by itself I have no idea! But I just enabled the radio profiles and voila!
    Man you guys are better than the TAC! Thanks so much to both you guys!
