I have an Instant AP-275 and i'm new to Instant. I cant get the "Outdoor" SSID to broadcast. The config is below, Thanks in advance!
ac:a3:1e:c0:5f:2a# show run
version 6.4.0.0-4.1.0
virtual-controller-country US
virtual-controller-key fbae5e0901a27461ca6b12122b5dd9499bf2a5c330300143ee
name instant-C0:5F:2A
terminal-access
telnet-server
clock timezone none 00 00
rf-band all
allow-new-aps
allowed-ap ac:a3:1e:c0:5f:2a
arm
wide-bands 5ghz
80mhz-support
min-tx-power 18
max-tx-power 127
band-steering-mode prefer-5ghz
air-time-fairness-mode fair-access
client-aware
scanning
ip dhcp pool
subnet 10.1.62.0
subnet-mask 255.255.255.0
dns-server 10.1.20.10
domain-name tecu.local
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
extended-ssid
mgmt-user admin 5a950dab7bcf4ea1d72a4c9ce7bdaeba
wlan access-rule default_wired_port_profile
index 0
rule any any match any any any permit
wlan access-rule wired-instant
index 1
rule masterip 0.0.0.0 match tcp 80 80 permit
rule masterip 0.0.0.0 match tcp 4343 4343 permit
rule any any match udp 67 68 permit
rule any any match udp 53 53 permit
wlan access-rule Outdoor
index 2
wlan ssid-profile Outdoor
enable
index 0
type employee
essid Outdoor
wpa-passphrase c5aacf473d9e6d68c3374dd425d1be1d6fb6848437be14b4
opmode wpa2-psk-aes
max-authentication-failures 0
vlan guest
auth-server InternalServer
rf-band all
captive-portal disable
dtim-period 1
inactivity-timeout 10000
broadcast-filter arp
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
auth-survivability cache-time-out 24
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
auto-whitelist-disable
https
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
wireless-containment none
ip dhcp 62
server-type Distributed,L2
server-vlan 62
ip-range 10.1.62.220 10.1.62.239
lease-time 60000
default-router 10.1.62.1
client-count 4
wired-port-profile wired-instant
switchport-mode access
allowed-vlan all
native-vlan guest
no shutdown
access-rule-name wired-instant
speed auto
duplex auto
no poe
type guest
no dot1x
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 1
shutdown
access-rule-name default_wired_port_profile
speed auto
duplex full
no poe
type employee
no dot1x
enet0-port-profile default_wired_port_profile
uplink
preemption
enforce none
failover-internet-pkt-lost-cnt 10
failover-internet-pkt-send-freq 30
failover-vpn-timeout 180
airgroup
disable
airgroupservice airplay
disable
description AirPlay
airgroupservice airprint
disable
description AirPrint
#3600
