Higher Education
last person joined: 22 days ago
Got questions on how to enable mobility in education? Submit them here!
SSID with Both MAC auth and 802.1x in ClearPass
  • 1.  SSID with Both MAC auth and 802.1x in ClearPass
    Posted Sep 16, 2015 09:14 PM
    How do you configure an SSID with both MAC auth and 802.1x against the same clearpass service?
    Currently i have 2 SSID.
    1NSU (802.1X  against AD)
    NSU (Mac auth for non-802.1x devices)
    Before winter Term I was planning to try to Merge the MAC auth into 1NSU so in campus we only have 1 SSID for those devices beside Guest.
    1. Do you try to do Mac Auth first then if it fail then do 802.1x auth?
    So wireless printer will connect to the 1NSU do Mac Auth obtain the role Printer. Then A student will connect to 1NSU Fail Mac auth then do 802.1x auth and obtain the role NSUStudents.
    Would it make sense? Or is better to keep it separate as i have now for easy of troubleshooting and management?
    Thank you
    Nils.
  • 2.  RE: SSID with Both MAC auth and 802.1x in ClearPass
    Posted Sep 16, 2015 09:20 PM
    This is not possible due to dynamic encryption protocols.
    You would need two SSIDs. MAC-address can only be used as an authorization source for 802.1X.
    It is common to have a multi-purpose guest, help/onboard, "dumb" device SSID along with your 802.1X SSID.
  • 3.  RE: SSID with Both MAC auth and 802.1x in ClearPass
    Posted Sep 16, 2015 09:27 PM
    Thank you Cappalli!
  • 4.  RE: SSID with Both MAC auth and 802.1x in ClearPass
    Posted Sep 16, 2015 09:30 PM
    Right that's the most common. Your users can pre-register their "dumb"
    devices so they pass MAC-auth and the fail-through would be a splash page
    with instructions and/or guest registration.
  • 5.  RE: SSID with Both MAC auth and 802.1x in ClearPass
    MVP
    Posted Sep 17, 2015 07:23 AM
    We use the "dumb" SSID with a captive portal to
    1. Onboard PEAP-MSCHAPv2 to 802.1X SSID
    or
    2. Register "dumb" device for mac auth
     The SSID also does mac auth for reghistered devices.
  • 6.  RE: SSID with Both MAC auth and 802.1x in ClearPass
    Posted Sep 17, 2015 09:02 AM
    Just spitballing here, but is there any product/configuration that would allow you to integrate those MAC addresses into the same database that your .1X devices authenticate off of?  Whereas .1X is used primarily via cert/credentials, a pre-registered device could match against an AD object associated with it, say.
    Not sure if it's possible, but the thought occurred to me.
  • 7.  RE: SSID with Both MAC auth and 802.1x in ClearPass
    Posted Sep 17, 2015 09:05 AM
    If the MAC address is referenced in AD or other external sources, sure!
    Tim
  • 8.  RE: SSID with Both MAC auth and 802.1x in ClearPass
    Posted Sep 17, 2015 09:47 AM
    I am new to ClearPass, so I am still feeling my way around the product. I am wondering why a rule couldn't be added to the enforcement policy to look at the mac address and then push the action to allow access if it is a match. If you have a lot of devices this would be ideal. For example the rule below:
    Conditions
    (Connection:Client-Mac-Address-Colon EQUALS xx:xx:xx:xx:xx:xx)
    Actions
    [Allow Access]
    Darin T. Williams
    Network Engineer
    University of Nebraska Computing Services
    225 Nebraska Hall
    Lincoln, Nebraska 68588-0521
    email: dtwilliams@nebraska.edu
    phone: 402.472.5884 cell:402.570.8293
    Date: Thursday, September 17, 2015 at 8:02 AM
    To: Darin >
    Subject: Re: SSID with Both MAC auth and 802.1x in ClearPass (Airheads Community Subscription Update)
    Hi darin-williams,
    pmauretti (New Member) posted a new Reply in Higher Education on 09-17-2015 06:02 AM :
    Browsing from your phone? Don't forget to download the Airheads Community App?
    ________________________________
    Reply | Give Kudos
    Airheads Community sent this message to dtwilliams@nebraska.edu.
    You are receiving this email because a new message matches your subscription to a board.
    To control which emails we send you please go to, manage your subscription & notification settings or unsubscribe.
  • 9.  RE: SSID with Both MAC auth and 802.1x in ClearPass
    MVP
    Posted Sep 17, 2015 09:51 AM
    Conditions
    Actions
    [Allow Access]
    Darin T. Williams
    Network Engineer
    225 Nebraska Hall
    To: Darin >
    Hi darin-williams,
    We are doing that with the registered mac addresses marked as Known and tagged with Username, etc. in the Endpoints database built in to ClearPass Policy Manager.
