SSID's and Signal Strength
  • 1.  SSID's and Signal Strength
    Posted Oct 03, 2012 07:25 AM
    In our current deployment, 02 SSID's are broadcasting on every AP. Out of which One SSID is showing 4 bars of signals while second SSID is showing 2 bars of Signals on the same laptops. Both SSID's are in same AP Group. Why it is happening?? I'm confused, Please advice
  • 2.  RE: SSID's and Signal Strength
    Posted Oct 03, 2012 07:35 AM
    Please download inssider or a third party tool to determine the real signal strength of those access points.  If you are using the windows built in utility to measure signal strength, it is not always accurate, especially if you are connected to an access point when you are measuring.
  • 3.  RE: SSID's and Signal Strength
    Posted Oct 03, 2012 10:55 AM
    I have "insider" in my laptop. I will check from that. Thank you so much for you all time advices.
