Am I hitting a limit or could something else be going on? I have old 105s at my office, we've got newer IAPs out in the field but this is all we have for our stuff. Sometimes I need to test things or make a network for one specifc and shortlived task. Right now I've got 5 Employee SSIDs and two Guest. Out of that the last Employee SSID I've made will not show up. I know that's a lot but as I've said I do a lot of testing and rework here. I think all the beacons are default, the only thing I really change or the security and further restrictions. I don't get an error or notice that things are not going to work it simply just does not show up.I've been tring to figure out what was going on for a bit and just figured it out after I deleted a network. The other one doesn't start working right away, I kill it and recreated it, then it popped up after syncing to the other IAPs in the building (5 total) I also tested disabling other SSIDs and that has no effect, if they exist at all that next SSID just doesn't end up broadcasting. Right now I only have 3 of the 7 networks active and only two are seen as the last one is the missing one.Any additional info needed just ask.
As far as I'm aware, the IAP-105 supports 8 SSIDs per radio, for a maximum of 16 per AP. You're close to the limit.
From the CLI, what does "show ap bss-table" return for your active SSIDs? Also, what version of Instant are you running?
