SSIDs/VLANs - (IAP-VPN)
  • 1.  SSIDs/VLANs - (IAP-VPN)
    Posted Apr 28, 2020 10:21 AM
    in implementing IAP-VPN and I ran into an issue about SSIDs and Vlans. We have about 8 SSID and about 60 Vlans configured on the master controller. what is the best practice to copy the vlans and the ssids into the IAPs from the controllers. I saw some videos but they all shows you how to create SSIDs/Vlans manually wish what I am trying to avoid.
    Any explanation on how, documents or videos is appropriate it.
  • 2.  RE: SSIDs/VLANs - (IAP-VPN)
    Posted Apr 28, 2020 10:28 AM
    What do you mean by copying SSIDs and VLANs?
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: SSIDs/VLANs - (IAP-VPN)
    Posted Apr 28, 2020 11:02 AM
    Hi victor,
    The Master controller has all the SSIDs configured on it and since the controller is will no longer manage the SSIDs how would I move the SSID to IAP (VC).
    From my understanding and forgive if I missed something. after implementing IAP-VPN the controller purpose becomes as VPN  concentrator and have no role of managing IAP/SSID or Vlans
    So how do you get all the SSIDs moved to the IAPs?
    Here is a short output of the current config of the SSIDs and Vlans on the controller.
    AUCONDC) # show ap remote essid ap-name AUCON1
    ESSID Summary
    ESSID APs Clients VLAN(s) Encryption
    AUCON1GUEST 1 5 10-16 Open
    AUCON1EMPL 1 0 10 17-20 WPA2 8021X AES
    AUCON1VIP 1 1 50 WPA2 PSK AES
    AUCON1SALES 1 15 20-25 WPA2 PSK AES
  • 4.  RE: SSIDs/VLANs - (IAP-VPN)
    Posted Apr 28, 2020 11:41 AM
    I see , the IAP uses a different command format compare to the controller.
    If you have AirWave you can push these settings, using a template based configuration .
    If you don't AirWave and you are planning to deploy several sites , i recommend manually configuring one site and then use that configuration as your template
    You can use the following as a template (this assumes you are using ClearPass) to get you going:
    wlan auth-server CPPM-RADIUS-SVR-1
    ip <CLEARPASS-IP-1>
    port 1812
    acctport 1813
    key <SHARED-KEY>
    rfc3576
    cppm-rfc3576-port 5999
    exit
    wlan auth-server CPPM-RADIUS-SVR-2
    ip <CLEARPASS-IP-2>
    port 1812
    acctport 1813
    key <SHARED-KEY>
    rfc3576
    exit
    wlan external-captive-portal SPLASH-CP-AUTH-PROFILE
    server <CLEARPASS-URL>
    port 443
    url "/guest/splash_page.php"
    auth-text ""
    https
    end
    commit apply
    configure terminal
    exit
    wlan access-rule EMPLOYEE-ROLE
    index 14
    rule any any match any any any permit
    exit
    wlan access-rule MACHINE-AUTH-ROLE
    index 15
    exit
    wlan access-rule REGISTERED-DEVICE-ROLE
    index 16
    end
    commit apply
    configure terminal
    wlan access-rule GUEST-ROLE
    index 17
    exit
    wlan access-rule GUEST-LOGON-ROLE
    index 18
    captive-portal external profile SPLASH-CP-AUTH-PROFILE
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    rule alias <CLEARPASS-URL> match tcp 80 80 permit
    rule alias <CLEARPASS-URL> match tcp 443 443 permit
    end
    commit apply
    configure terminal
    wlan ssid-profile <802.1X-SSID-PROFILE>
    enable
    index 5
    type employee
    essid <802.1X-SSID>
    opmode wpa2-aes
    max-authentication-failures 0
    vlan <SECURE-VLAN-ID>
    set-role Aruba-User-Role value-of
    rf-band all
    captive-portal disable
    dtim-period 1
    broadcast-filter all
    server-load-balancing
    radius-accounting
    radius-interim-accounting-interval 5
    g-min-tx-rate 12
    a-min-tx-rate 12
    multicast-rate-optimization
    dynamic-multicast-optimization
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    okc
    end
    commit apply
    configure terminal
    wlan ssid-profile <GUEST-SSID-PROFILE>
    enable
    index 6
    type guest
    essid <GUEST-SSID>
    opmode opensystem
    vlan <GUEST-VLAN-ID>
    rf-band all
    mac-authentication
    dtim-period 1
    enforce-dhcp
    radius-accounting
    g-min-tx-rate 12
    a-min-tx-rate 12
    end
    commit apply
  • 5.  RE: SSIDs/VLANs - (IAP-VPN)
    Posted Apr 28, 2020 12:13 PM
    Thanks Victor,
    So far all I have is Airwave, 72xx controller and IAP. it looks like I will be using Airwave for a template based configuration. any docs or tips on how to do that? I will do some googling on my side to see if I can find some examples.
    Thanks!
    Xzyan.
  • 6.  RE: SSIDs/VLANs - (IAP-VPN)
    Posted Apr 28, 2020 12:18 PM
  • 7.  RE: SSIDs/VLANs - (IAP-VPN)
    Posted Apr 28, 2020 01:03 PM
    Thanks Victor! I will go through the chapters.
  • 8.  RE: SSIDs/VLANs - (IAP-VPN)
    Posted Apr 28, 2020 07:00 PM
    Hello again!
    After reading the chapters, there is no where it mentions how to copy the SSID's or Vlans from the controller via airwave or central and move them to IAP (VC).
    My goal is to copy or move all the SSIDs/Vlans from the controllers to IPA (VC). Any where I look it mentioned that I have to create the SSID and Vlans on the IAP manually..
    any advise?
  • 9.  RE: SSIDs/VLANs - (IAP-VPN)
    Posted Apr 28, 2020 08:08 PM
    Today there isn’t a way to copy and paste the controller config into the Aruba Instant or viceversa but you can use AirWave to push the config to all your IAPS
    Thank you
    Victor Fabian
