Hi everybody,
For 5 Aruba switchs 2530-8G
May I create one SSL certificat and intall it on all my switchs ?
If yes, how should I proceed ?
Regards
You can self generated a certificat (via crypto pki...)
On set a wildcard certificat on the switch
Yes, I've allready done it on one switch.
But for the others ? Must I generate certificate switch by switch ?
Or can I use the first one ? If yes, how should I proceed ?
@bfriconneau wrote:Yes, I've allready done it on one switch.But for the others ? Must I generate certificate switch by switch ?Or can I use the first one ? If yes, how should I proceed ?
Do you have self generated ?
Yes, self generated
@bfriconneau wrote:Yes, self generated
Yes, need to generated on all switches
OK.
I used the self generated certificate, because I have'nt understand how to create one using Trust Anchor.
How can I do ? Is there a method or tutorial somewhere ?
Greetings!
You can refer to this section of the ArubaOS-Switch Hardening Guide for a step-by-step procedure for creating a TA profile, installing the TA root certificate, generating a certificate signing request, and installing the resulting certificate.
