SSL Certificate generation/installation issue
  • 1.  SSL Certificate generation/installation issue
    Posted Jan 23, 2014 04:20 AM
    Hello community,
    I am having a problem with getting an SSL certificate installed in my AMP 7.6.0.
    I generated the CSR as mentioned in one of the replies in this thread:
    http://community.arubanetworks.com/t5/AirWave-and-Network-Management/How-to-install-certificate/m-p/7076/highlight/true#M180
    I was able to generate the CSR, get the certificate from the CA and install them just like described.
    However, When I restarted the appachi nothing changed and the old SSL is still appearing on the HTTPS URL.
    - How can I install the certificate correctly?
    - What about installing the certificate usign the GUI? Should I merge the generted certificate with the private key before installing it?
    - What if my certificate is published using an intermediate certificate? should I merge all the certificates in a p12 cert type file?
    Thanks.
    Amjad
  • 2.  RE: SSL Certificate generation/installation issue
    Posted Jan 26, 2014 01:00 AM
    I opened a ticket with the TAC and they provided the procedure. It is available in this link:
    http://goo.gl/h5jOwc
    The procedures I was following is not complete. it is missing some steps.
