Network Management
  • 1.  SSL Certificate Issue
    Posted Aug 12, 2021 11:33 PM
    Edited by Greg_W Aug 17, 2021 09:50 AM
    Hello everyone,
    I am having some trouble getting a certificate onto our 2930f switch. We would like to add one in order to make use of an TLS connection when accessing the GUI via the switch's IP address.
    We do not have ClearPass, I am looking for a way to manually upload these certificates. I have tried to generate a CSR but the commands I have found thus far online don't seem to be working and the generate CSR option in the GUI is greyed out.
    I have also tried to generate a certificate from our local CA but I cannot quite figure out how to upload this into the switch for use.
    Any advice would be greatly appreciated.
    Thanks!
  • 2.  RE: SSL Certificate Issue
    Posted Aug 18, 2021 03:19 PM
    What command do you are using ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: SSL Certificate Issue
    Posted Aug 20, 2021 09:20 AM
    The command I had tried to use to generate a CSR was:
    crypto pki csr {rsa key_len <key_val> |{ec curve-name <key_val>} common_name <common_val> country <country_val> state_or_province <state> city <city_val> organization <organization_val> unit <unit_val> email <email_val>
    But this didn't seem to work and in the GUI the CSR option is greyed out.
    My second thought was to just get my internal CA to generate a certificate which I was able to do but I am scratching my head actually trying to get the certificate into the switch for use.
  • 4.  RE: SSL Certificate Issue
    Posted Aug 24, 2021 05:45 AM
    As far as I know, you will need to create the CSR on the switch, but with a slightly different command.
    Check the ArubaOS Security Guide for 2930F, starting at page 738 to see the steps.
  • 5.  RE: SSL Certificate Issue
    Posted Aug 30, 2021 12:49 PM
    Thanks a lot! This is exactly what I was looking for.
  • 6.  RE: SSL Certificate Issue
    Posted Dec 02, 2024 07:50 PM
    I've tried the crypto pki create-csr <cert name> but it doesn't accept anything as a valid certificate name. Running 16.10 on a 2930F.
    Aruba-2930F-8G-PoEP-2SFPP(config)# web-management ssl
    https cannot be enabled with no certificate present. To install a certificate,
    use one of the following commands:
      * 'crypto pki enroll-self-signed...'
      * 'crypto pki create-csr ...'
    Aruba-2930F-8G-PoEP-2SFPP(config)# crypto pki enroll-self-signed
     certificate-name      Name of the local certificate.
    Aruba-2930F-8G-PoEP-2SFPP(config)# crypto pki enroll-self-signed selfsignedcert
    Invalid input: selfsignedcert
    Aruba-2930F-8G-PoEP-2SFPP(config)# crypto pki create-csr selfsignedcert
    The 16.10 documentation makes mention of needing to generate using crypto key generate cert but that doesn't work:
    Aruba-2930F-8G-PoEP-2SFPP(config)# crypto key generate cert
    Invalid input: cert
    The only valid options presented are autorun-key and ssh.
    The documentation has me going around in circles with these commands. There is nowhere in the web UI to generate a certificate. I simply cannot figure out create a self-signed cert on this device based on the provided documentation that doesn't match what the CLI is giving me.
    Is it just because it's a small 8-port unit and lacks the horsepower to do anything useful, and SSL isn't actually supported? What is missing here?
  • 7.  RE: SSL Certificate Issue
    Posted Dec 02, 2024 07:54 PM
    Try the command: "crypto pki enroll-self-signed certificate-name selfsignedcert"
    certificate-name is a keyword in the command, not to be replaced by de name of the certificate which comes after that keyword.
  • 8.  RE: SSL Certificate Issue
    Posted Dec 03, 2024 09:29 AM
    Ah, OK, that makes a whole lot more sense, and was not clear from the doc or the inline help. There is a significant documentation gap here.
    Perhaps someone from HPE tech pubs can enlighten us as to why AOS-Switch is not included in the CLI bank along with all the rest of the Aruba product line? There's a document out there that is moderately useful as a Rosetta Stone to go between Cisco, AOS-S, and AOS-CX command lines, but it's not complete or particularly well organized. Documentation pages used to have a feedback link but that seems to be hit or miss these days.
  • 9.  RE: SSL Certificate Issue
    Posted May 02, 2025 06:13 AM
    I'm in a really similar boat. I setup a bunch of Aruba 2530 12 port, 24 port and 48 port switches. When I did the erase all command to factory reset or while upgrading to a new firmware (YA16.11.0024), part of the boot process is creating a self signed cert so when I use command
    web-management ssl
    There is no issue.
    However, the current Aruba 2530-24G-PoEP J9773A that I'm working on won't generate the certificate. I've tried both crypto pki enroll-self-signed and create-csr and had no luck (switch asked me to configure identity profile and subject field).
