SSL Certificate on MM and MC
  • 1.  SSL Certificate on MM and MC
    Posted May 11, 2020 05:02 AM
    we currently have 1 Mobility Master that is managing 2 Mobility Controllers. The controllers are active/active.
    I need to buy the SSL cert. for the Captive Portal authentication.
    How many cert. do we need? Just 1 for the MM that will push the cert. to the controllers?
    1+1 cert. for both controllers? Or 3 cert. one for each controller + master?
    OS version: 8.2
    Thank you very much for any possible response
  • 2.  RE: SSL Certificate on MM and MC
    Posted May 11, 2020 06:23 AM
    For captive portal authentication , you only need 1 cert that can be use on all your controllers
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: SSL Certificate on MM and MC
    Posted May 11, 2020 06:26 AM
    Thank you a lot Victor.
    By the way, the captive portal will not be internally but on ClearPass, I hope this won't change anything
  • 4.  RE: SSL Certificate on MM and MC
    MVP EXPERT
    Posted May 11, 2020 09:23 AM
    Just to add, take a look at the CPPM Cert tech note as well. Contains lots of good info and explanations.
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=33288
  • 5.  RE: SSL Certificate on MM and MC
    Posted May 12, 2020 12:16 PM
    Sounds like you already have the cert on the ClearPass server and just want to know what you need on the controller? Both will need to have a certificate, you can use the same cert if you use Subject Alternative Name (SAN) certs and specify cppm.yourdomain.com and controller.yourdomain.com, some other options covered in the link below.
    https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Web-Login-NAS-Address-configuration-options-in-single-and-multi/ta-p/275426
