SSL Certificates in a Master / Standby Configuration
  • 1.  SSL Certificates in a Master / Standby Configuration
    Posted Apr 04, 2012 01:10 AM
    Is there a way you can move the private key between the master and standby controllers so you can have the same server certificate loaded.
  • 2.  RE: SSL Certificates in a Master / Standby Configuration
    Posted Apr 04, 2012 11:29 AM
    I believe if you perform a full flash backup on the controller, you can pull the certificate files from the tar.gz
    You should then be able to import these certs to your other controllers.
    Good Luck,
    -Eliasz
