ssl error Captive portal
  • 1.  ssl error Captive portal
    Posted Oct 29, 2016 10:02 AM
    We got a few clientes which dont want this ssl error
    I was reading this
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-replace-Captive-Portal-SSL-certificate-and-get-NO-invalid/ta-p/179946
    It says that we need to use linux to generate CSR Request
    But what happens if we Generate it with the controller
    IS there any difference????
    Also
    If i put it to use HTTP instead of HTTPS i guess ill get rid of the error.  But then that would be insecure right? as user and pass will be on clearpatext?
    Any thoughs on this last one?
    Cheers
    Carlos
  • 2.  RE: ssl error Captive portal
    Posted Oct 29, 2016 10:07 AM
    It's recommended to use an external server to generate the key pair so you have a backup of the private key and/or so you can use the cert on multiple servers. It's not a requirement though. Take a look at the FAQ.
