SSL - How do I Import a Private Key
  • 1.  SSL - How do I Import a Private Key
    Posted Oct 14, 2018 04:48 AM
    I am setting up SAN SSL certificates for a pair of 7200's controllers running as master/master.
    I created the CSR's for offline (outside of the controllers) using Open SSL. As the certificate has been created offline I need to import the private keys, and the intermediary certificate into the controllers.
    I have  the following two questions that I hope the forum can help me with :
    1. How do I import a private key into a controller? There isn’t an option in the GUI to import private keys, nor can I find any documentation to import private keys via CLI commands
    2. Adding an intermediary certificate – Can I copy the intermediary certificate into the SAN certificate? Would this work correctly within an Aruba Controller?
    KR
  • 2.  RE: SSL - How do I Import a Private Key
    Posted Oct 14, 2018 05:24 AM
    The private key needs to be bundled with the cert that you import.  Easiest thing to do is to convert the cert and intermediates into pem format and then chain them together into one file.
    The order should be cert--intermediate1--intermediate2--privkey
    When importing enter the private key password if there is one.
  • 3.  RE: SSL - How do I Import a Private Key
    Posted Oct 14, 2018 06:20 AM
    Thank you for the solution.
    Much appreciated!
