日本語フォーラム
last person joined: 10 days ago
HPE Aruba Networking のソリューション、ネットワークマーケットに関する日本語ディスカッションフォーラム
"SSL Library Error"ログについて
  • 1.  "SSL Library Error"ログについて
    Posted Apr 21, 2022 10:15 PM
    Aruba Controller(7010)のOSを8.7.1.9に更新したところ、以下のようなログが大量に出力されるようになりました。
    (Aruba) *[mm] #show log system all
    Apr 22 10:35:42 httpd[7125]: <350005> <7155> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:810526940
    Apr 22 10:35:42 httpd[7125]: <350005> <7156> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:812624092
    Apr 22 10:35:42 httpd[7125]: <350005> <7157> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:814721244
    Apr 22 10:35:42 httpd[7125]: <350005> <7158> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:816818396
    Apr 22 10:35:42 httpd[7125]: <350005> <7159> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:818915548
    Apr 22 10:35:42 httpd[7125]: <350005> <7161> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:823109852
    Apr 22 10:35:42 httpd[7125]: <350005> <7160> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:821012700
    Apr 22 10:35:42 httpd[7125]: <350005> <7162> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:825207004
    Apr 22 10:35:42 httpd[7125]: <350005> <7163> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:827304156
    Apr 22 10:35:42 httpd[7125]: <350005> <7164> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:829401308
    Apr 22 10:35:42 httpd[7125]: <350010> <7165> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
    Apr 22 10:35:42 httpd[7125]: <350010> <7166> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
    Apr 22 10:35:42 httpd[7125]: <350010> <7167> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
    Apr 22 10:35:42 httpd[7125]: <350010> <7168> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
    Apr 22 10:35:42 httpd[7125]: <350010> <7169> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
    Apr 22 10:35:42 httpd[7125]: <350010> <7170> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
    ログ設定は以下のとおりです。
    また、WebアクセスにChromeとEdgeどちらを使用しても変化ありませんでした。
    このログ出力を止めるにはどのような設定が必要でしょうか。
    (Aruba) *[mm] #show logging level
    LOGGING LEVELS
    Facility Level
    arm warnings
    network warnings
    security warnings
    system warnings
    user warnings
    wireless warnings
    (Aruba) *[mm] #show debug
    DEBUG LEVELS
    Facility Level Debug Value Sub Category Process
    (Aruba) *[mm] #
  • 2.  RE: "SSL Library Error"ログについて
    Posted May 10, 2022 01:42 AM
    断定はできないですが、表示上の不具合で似た事象の報告は社内で確認できました。同事象であれば、抑制方法は無く、無視いただいてよいものとなります。
    検証環境であれば、最新のAOS 8.10 でも発生するかご確認頂ければ幸いです。
    また、実環境への影響がある場合は、サポートにもご相談下さい。
    Keita Shimono,
    Aruba Japan SE Manager & Airheads Leader
  • 3.  RE: "SSL Library Error"ログについて
    Posted May 10, 2022 03:19 AM
    ご返信ありがとうございます。
    実環境なので8.10は検証出来ないですが、特に動作自体に問題は見受けられません。
    表示上の不具合ということであればgrepすれば困らないので無視することにします。
