Hi.
Herman already pointed out. This is OfficeConnect line of switches. Currently replaced by Instant ON line. 1950 is in fact Comware based product. You will have better luck asking in Comware and Instant ON forums.
You can also look at asp.arubanetworks.com for OfficeConnect 1950 Firmware. I beleive that this is Comware 5 product. If you look into Comware 5 documentation like Security Guide, you can find some useful information how to proceed.
Here is the link to 5600 switch Security guide. Not really the model nor version you have, but can help you get the idea where to look.
Your best bet currently is to upgrade, if you didn't already, to latest available OfficeConnect 1950 FW and see if it will solve your issue. This product is discontinued so no new features are expected.
Best; Gorazd
Gorazd Kikelj
MVP Expert 2023
Original Message:
Sent: Aug 29, 2023 12:57 AM
Subject: SSL TO TLS Enable
I am facing an issue in HP switch which is having SSL 3.0 service and it showing in Vulnerability. And i want to allow the TLS service in same model but
there is no feature of TLS 1.2 service. Please help me here to identify the same, so that i can be able to disable the SSL service and can enable the TLS service.
( Hpe 1950 12 )
Ryan
