Wired Intelligent Edge
stacking interface add stk
  • 1.  stacking interface add stk
    Posted Jan 08, 2014 03:19 PM
    Hope someone can help.........please.....................
    We are trying to stack an Aruba S3500 and a S2500 without traditional stacking fiber cables. We would like to lag or ether channel 2 ports to the switches. DOes anyone have commands to do this. I have tried to re-search it all day and can't find anything without using the fiber cables in the slots......
    We are trying to use ports 1 and 2 for the channel between switches.
    Can someone help me please......................
    Wall
  • 2.  RE: stacking interface add stk
    Posted Jan 08, 2014 03:30 PM
    Wally,
    Ports 22/23 and 46/47 are the QA qualified base stack ports for the S2500s and S3500-24P/T or 48P/T. The command to enable stacking on those ports is as follows:
    (host) # add stacking interface stack <module/port>
    So to enable port 46 or 47 it would be as follows:
    add stacking interface stack 0/46
    or
    add stacking interface stack 0/47
    It can be done from config mode or executive mode since they modify the stacking database and not the startup/running config.
    The user-guide has these commands as well as the validated topologies.
    http://www.arubanetworks.com/techdocs/ArubaOS_73_Web_Help/Default.htm#mas_guides/aruba_stack/Stacking.htm%3FTocPath%3DArubaStack%7C_____0
    Best regards,
    Madani
  • 3.  RE: stacking interface add stk
    Posted Jan 08, 2014 03:51 PM
    Thanks so much......The document alone was a huge help...........
    Wally
