Wired Intelligent Edge
Stateful DHCPv6 support for wired networks
  • 1.  Stateful DHCPv6 support for wired networks
    Posted Oct 31, 2019 03:36 PM
    It does not seem the stateful DHCPv6 feature is supported for wired networks using Aruba switches. Has anybody had success setting up stateful DHCPv6 for their wired environment?
    Switch Model we are using is:
    3810M-40G-8SR-PoE
    Software version we are running is:
    show version
    Image stamp:    /ws/swbuildm/rel_yakima_qaoff/code/build/bom(swbuildm_rel_yakima_qaoff_rel_yakima)
                    Nov 21 2018 05:13:08
                    KB.16.08.0001
                    468
    Boot Image:     Primary
    Boot ROM Version:    KB.16.01.0009
    Active Boot ROM:     Primary
    ADSB-106-MDF(config)# show flash
    Image             Size (bytes) Date     Version
    Primary Image    :    34017600 11/21/18 KB.16.08.0001
    Secondary Image  :    34017600 11/21/18 KB.16.08.0001
    Boot ROM Version
    Primary Boot ROM Version   : KB.16.01.0009
    Secondary Boot ROM Version : KB.16.01.0009
    Default Boot Image   : Primary
    Default Boot ROM     : Primary
    Also using the helper command to reach the DHCPv6 server:
    Here is the switch configuration:
    show running-config vlan 1000
    Running configuration:
    vlan 1000
       name "PROD"
       tagged 1/20,2/21
       untagged 3/20,3/30
       ip helper-address x.x.x.x
       ip address x.x.x.x 255.255.255.0
       ip igmp
       ip ospf x.x.x.x passive
       ip ospfx.x.x.x area 0.0.0.1
       ipv6 enable
       ipv6 address x:x:x:x::1/64
       ipv6 ospf3 passive
       ipv6 ospf3 area 0.0.0.1
       ipv6 nd ra managed-config-flag
       ipv6 helper-address unicast x:x:x:x::100
       jumbo
       exit
    dhcpv6-relay
    We are running dual stack and DHCPv4 works fine. For v6 end user clients get the prefix portion of the network correct, but uses SLAAC to generate the last /64 bit host portion of the address. Even when having the M flag set to 1, clients are not getting assignment from the v6 server.
  • 2.  RE: Stateful DHCPv6 support for wired networks
    Posted Nov 01, 2019 05:54 AM
    Hi, DHCPv6 stateful does work with ArubaOS-Switch, I've done quite a bit of work on it.
    What client OS are you using? Android and, I believe, chromebooks do not support DHCPv6.
    Are you able to get a packet capture from the client to see if the DHCPv6 SOLICIT and REPLY are being exchanged?
